Q-in-Q question
  • Question
  • Updated 4 years ago
  • Answered
Hi
how is q-in-q called in XOS ? Is it vman ?
Is vman limited to license ?
What functionality is supported with Advanced Edge ?
I am trying to set up q-in-q with double tagging  usig x450-24 with XOS version 12.4.5.3.
Photo of Dawid Chrzan
Dawid Chrzan
  • 362 Points 250 badge 2x thumb
Posted 4 years ago
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,346 Points 10k badge 2x thumb
yes, VMAN is Extreme's name for 802.1ad.
VMAN capabilty is not restricted to a given license. Btw, you can easily check what feature is in what license level reading this doc: http://documentation.extremenetworks.com/FLR/downloads/ExtremeXOS_Feature_License_Requirements.pdf
Stephane
Dawid Chrzan
Is it restricted to the platform or the software ? - because i came across contradictory info.
Is it possible to run it on x450-24t  XOS version 12.4.5.3.  ?
The hardware needs to support it, this is the only restriction, as the software feature is included with the lowest license level (L2-Edge). Is that an original x450-24t, or a x450a/e-24t? I don't really recall for the original x450, but I think it has that capability.
Edit:
VMAN is listed in the original x450 DS.
Looking into the 12.4 Concepts Guide, in the Appendixes, x450 is listed as well for the following:
- vMANs—Q-in-Q tunneling (IEEE 802.1ad vMAN tunneling standard)
- vMANs—Egress queue selection based on 802.1p value in S-tag
- vMANs—Egress queue selection based on 802.1p value in C-tag
http://extrcdn.extremenetworks.com/wp-content/uploads/2014/02/100375-00_Rev_02_ExtremeXOS_12.4.2_Con...
