QoS 802.1p mapping on ingress port
  • Question
  • Updated 3 years ago
  • Answered
Hi all,
I would like to do a 802.1p marking on the ingress port on the switch, because the end node itself cannot mark 802.1p or DSCP value on its frame/packet.
How I can do this?
BR
Lu
Photo of Zhang Lu
Zhang Lu
  • 124 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,838 Points 5k badge 2x thumb
Official Response
Christoph,
Here is a example.  Lets say your ingress port is 1:1 and you want to add a dot1p value of 4 to all the traffic coming into that port.  This is what you would do.
1. Apply this ACL to port 1:1:
entry replace_dot1p_4{
if match all {
} then {
    permit  ;
    replace-dot1p-value 4  ;
Note: Dot1p is in the 802.1q part of the frame so 802.1q tagged frames will have the dot1p value.  If port 1:1 is untagged it will not work.
Link to GTAC Knowledge Article on this topic
(Edited)
Official Response
Zhang,
Yes you can.  You can do this by using an Ingress ACL to add a dscp value based on the diffserv replacement mappings on the switch.  In this example below a DSCP code point of 32 will be added on egress.
Note:  When you add a new DSCP value on ingress it will not be examined on egress.  But the next switch in line will be able to prioritize the traffic on egress.
1 Apply ACL to your ingress port:
entry replace_DSCP_32 {
if match all {
then {
    qosprofile qp5 ;
    replace-dscp  ;
2. Change the diffserv replacement mappings
Switch# configure diffserv replacement qp5 code-point 32
Switch# show diffserv replacement
QOSProfile->CodePoint mapping:
        QP1 -> 00
        QP5 -> 32
        QP8 -> 56
Hope this helps.
(Edited)
