QoS and Bandwidth Throttling
  • Question
  • Updated 5 years ago
  • Answered
Create Date: Mar 21 2012 7:00AM
Typically, the ports are only able to be given one QoS profile or a Vlan is assigned only one QoS profile. In this setup, we were looking to limit the bandwidth (which can be done on the port level, but not so much the Vlan level) and assign two QoS profiles to one port. If we assigned the QoS profiles based on the Vlan, this would handle giving the vital Vlan higher priority over the littlest Vlan, but the only way we would be able to limit the bandwidth would be thru limiting the bandwidth on the port level. The issue I had was that the ports, as mentioned before, can only have one QoS profile assigned to them which would limit the bandwidth according to only one of the QoS profiles. Is there any way around this? So that the bandwidth can be limited on the uplinked ports to the AP, containing different Vlans? For example, when one Vlan's traffic comes thru, it gets most of the bandwidth, and when the other Vlan comes thru, it gets less bandwidth allocation. The tricky part is that both Vlans are on the same port, tagged with one Vlan and untagged in the other.
Thanks,
Here is the current QoS configuration on the switch:
<!--[if gte mso 9]><xml>
<o:DocumentProperties>
<o:Revision>0</o:Revision>
<o:TotalTime>0</o:TotalTime>
<o:Pages>1</o:Pages>
<o:Words>63</o:Words>
<o:Characters>365</o:Characters>
<o:Company>Carousel Industries</o:Company>
<o:Lines>3</o:Lines>
<o:Paragraphs>1</o:Paragraphs>
<o:CharactersWithSpaces>427</o:CharactersWithSpaces>
<o:Version>14.0</o:Version>
</o:DocumentProperties>
<o:OfficeDocumentSettings>
<o:AllowPNG />
</o:OfficeDocumentSettings>
</xml><![endif]--> <!--[if gte mso 9]><xml>
<w:WordDocument>
<w:View>Normal</w:View>
<w:Zoom>0</w:Zoom>
<w:TrackMoves />
<w:TrackFormatting />
<w:PunctuationKerning />
<w:ValidateAgainstSchemas />
<w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
<w:IgnoreMixedContent>false</w:IgnoreMixedContent>
<w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
<w:DoNotPromoteQF />
<w:LidThemeOther>EN-US</w:LidThemeOther>
<w:LidThemeAsian>JA</w:LidThemeAsian>
<w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript>
<w:Compatibility>
<w:BreakWrappedTables />
<w:SnapToGridInCell />
<w:WrapTextWithPunct />
<w:UseAsianBreakRules />
<w:DontGrowAutofit />
<w:SplitPgBreakAndParaMark />
<w:EnableOpenTypeKerning />
<w:DontFlipMirrorIndents />
<w:OverrideTableStyleHps />
<w:UseFELayout />
</w:Compatibility>
<m:mathPr>
<m:mathFont m:val="Cambria Math" />
<m:brkBin m:val="before" />
<m:brkBinSub m:val="--" />
<m:smallFrac m:val="off" />
<m:dispDef />
<m:lMargin m:val="0" />
<m:rMargin m:val="0" />
<m:defJc m:val="centerGroup" />
<m:wrapIndent m:val="1440" />
<m:intLim m:val="subSup" />
<m:naryLim m:val="undOvr" />
</m:mathPr></w:WordDocument>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true"
DefSemiHidden="true" DefQFormat="false" DefPriority="99"
LatentStyleCount="276">
<w:LsdException Locked="false" Priority="0" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Normal" />
<w:LsdException Locked="false" Priority="9" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="heading 1" />
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2" />
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3" />
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4" />
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5" />
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6" />
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7" />
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8" />
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9" />
<w:LsdException Locked="false" Priority="39" Name="toc 1" />
<w:LsdException Locked="false" Priority="39" Name="toc 2" />
<w:LsdException Locked="false" Priority="39" Name="toc 3" />
<w:LsdException Locked="false" Priority="39" Name="toc 4" />
<w:LsdException Locked="false" Priority="39" Name="toc 5" />
<w:LsdException Locked="false" Priority="39" Name="toc 6" />
<w:LsdException Locked="false" Priority="39" Name="toc 7" />
<w:LsdException Locked="false" Priority="39" Name="toc 8" />
<w:LsdException Locked="false" Priority="39" Name="toc 9" />
<w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption" />
<w:LsdException Locked="false" Priority="10" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Title" />
<w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font" />
<w:LsdException Locked="false" Priority="11" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Subtitle" />
<w:LsdException Locked="false" Priority="22" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Strong" />
<w:LsdException Locked="false" Priority="20" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Emphasis" />
<w:LsdException Locked="false" Priority="59" SemiHidden="false"
UnhideWhenUsed="false" Name="Table Grid" />
<w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text" />
<w:LsdException Locked="false" Priority="1" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="No Spacing" />
<w:LsdException Locked="false" Priority="60" SemiHidden="false"
UnhideWhenUsed="false" Name="Light Shading" />
<w:LsdException Locked="false" Priority="61" SemiHidden="false"
UnhideWhenUsed="false" Name="Light List" />
<w:LsdException Locked="false" Priority="62" SemiHidden="false"
UnhideWhenUsed="false" Name="Light Grid" />
<w:LsdException Locked="false" Priority="63" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Shading 1" />
<w:LsdException Locked="false" Priority="64" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Shading 2" />
<w:LsdException Locked="false" Priority="65" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium List 1" />
<w:LsdException Locked="false" Priority="66" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium List 2" />
<w:LsdException Locked="false" Priority="67" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Grid 1" />
<w:LsdException Locked="false" Priority="68" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Grid 2" />
<w:LsdException Locked="false" Priority="69" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Grid 3" />
<w:LsdException Locked="false" Priority="70" SemiHidden="false"
UnhideWhenUsed="false" Name="Dark List" />
<w:LsdException Locked="false" Priority="71" SemiHidden="false"
UnhideWhenUsed="false" Name="Colorful Shading" />
<w:LsdException Locked="false" Priority="72" SemiHidden="false"
UnhideWhenUsed="false" Name="Colorful List" />
<w:LsdException Locked="false" Priority="73" SemiHidden="false"
UnhideWhenUsed="false" Name="Colorful Grid" />
UnhideWhenUsed="false" Name="Light Shading Accent 1" />
UnhideWhenUsed="false" Name="Light List Accent 1" />
UnhideWhenUsed="false" Name="Light Grid Accent 1" />
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1" />
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1" />
UnhideWhenUsed="false" Name="Medium List 1 Accent 1" />
<w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision" />
<w:LsdException Locked="false" Priority="34" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="List Paragraph" />
<w:LsdException Locked="false" Priority="29" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Quote" />
<w:LsdException Locked="false" Priority="30" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Intense Quote" />
UnhideWhenUsed="false" Name="Medium List 2 Accent 1" />
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1" />
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1" />
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1" />
UnhideWhenUsed="false" Name="Dark List Accent 1" />
UnhideWhenUsed="false" Name="Colorful Shading Accent 1" />
UnhideWhenUsed="false" Name="Colorful List Accent 1" />
UnhideWhenUsed="false" Name="Colorful Grid Accent 1" />
UnhideWhenUsed="false" Name="Light Shading Accent 2" />
UnhideWhenUsed="false" Name="Light List Accent 2" />
UnhideWhenUsed="false" Name="Light Grid Accent 2" />
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2" />
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2" />
UnhideWhenUsed="false" Name="Medium List 1 Accent 2" />
UnhideWhenUsed="false" Name="Medium List 2 Accent 2" />
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2" />
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2" />
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2" />
UnhideWhenUsed="false" Name="Dark List Accent 2" />
UnhideWhenUsed="false" Name="Colorful Shading Accent 2" />
UnhideWhenUsed="false" Name="Colorful List Accent 2" />
UnhideWhenUsed="false" Name="Colorful Grid Accent 2" />
UnhideWhenUsed="false" Name="Light Shading Accent 3" />
UnhideWhenUsed="false" Name="Light List Accent 3" />
UnhideWhenUsed="false" Name="Light Grid Accent 3" />
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3" />
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3" />
UnhideWhenUsed="false" Name="Medium List 1 Accent 3" />
UnhideWhenUsed="false" Name="Medium List 2 Accent 3" />
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3" />
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3" />
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3" />
UnhideWhenUsed="false" Name="Dark List Accent 3" />
UnhideWhenUsed="false" Name="Colorful Shading Accent 3" />
UnhideWhenUsed="false" Name="Colorful List Accent 3" />
UnhideWhenUsed="false" Name="Colorful Grid Accent 3" />
UnhideWhenUsed="false" Name="Light Shading Accent 4" />
UnhideWhenUsed="false" Name="Light List Accent 4" />
UnhideWhenUsed="false" Name="Light Grid Accent 4" />
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4" />
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4" />
UnhideWhenUsed="false" Name="Medium List 1 Accent 4" />
UnhideWhenUsed="false" Name="Medium List 2 Accent 4" />
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4" />
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4" />
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4" />
UnhideWhenUsed="false" Name="Dark List Accent 4" />
UnhideWhenUsed="false" Name="Colorful Shading Accent 4" />
UnhideWhenUsed="false" Name="Colorful List Accent 4" />
UnhideWhenUsed="false" Name="Colorful Grid Accent 4" />
UnhideWhenUsed="false" Name="Light Shading Accent 5" />
UnhideWhenUsed="false" Name="Light List Accent 5" />
UnhideWhenUsed="false" Name="Light Grid Accent 5" />
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5" />
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5" />
UnhideWhenUsed="false" Name="Medium List 1 Accent 5" />
UnhideWhenUsed="false" Name="Medium List 2 Accent 5" />
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5" />
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5" />
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5" />
UnhideWhenUsed="false" Name="Dark List Accent 5" />
UnhideWhenUsed="false" Name="Colorful Shading Accent 5" />
UnhideWhenUsed="false" Name="Colorful List Accent 5" />
UnhideWhenUsed="false" Name="Colorful Grid Accent 5" />
UnhideWhenUsed="false" Name="Light Shading Accent 6" />
UnhideWhenUsed="false" Name="Light List Accent 6" />
UnhideWhenUsed="false" Name="Light Grid Accent 6" />
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6" />
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6" />
UnhideWhenUsed="false" Name="Medium List 1 Accent 6" />
UnhideWhenUsed="false" Name="Medium List 2 Accent 6" />
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6" />
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6" />
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6" />
UnhideWhenUsed="false" Name="Dark List Accent 6" />
UnhideWhenUsed="false" Name="Colorful Shading Accent 6" />
UnhideWhenUsed="false" Name="Colorful List Accent 6" />
UnhideWhenUsed="false" Name="Colorful Grid Accent 6" />
<w:LsdException Locked="false" Priority="19" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis" />
<w:LsdException Locked="false" Priority="21" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis" />
<w:LsdException Locked="false" Priority="31" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference" />
<w:LsdException Locked="false" Priority="32" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Intense Reference" />
<w:LsdException Locked="false" Priority="33" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Book Title" />
<w:LsdException Locked="false" Priority="37" Name="Bibliography" />
<w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading" />
</w:LatentStyles>
</xml><![endif]--> <!--[if gte mso 10]>
<style>
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:Cambria;
mso-ascii-font-family:Cambria;
mso-ascii-theme-font:minor-latin;
mso-hansi-font-family:Cambria;
mso-hansi-theme-font:minor-latin;}
</style>
<![endif]--> <!--StartFragment-->
vital vlan, important vlan, necessary vlan (most bandwidth, higher priority)
littlest vlan (least bandwidth, lower priority)
create qosprofile qp3
conf vlan vital qosprofile qp3
conf vlan important qosprofile qp3
conf vlan necessary qosprofile qp3
conf vlan littlest qosprofile qp1
conf dot1p type 2 qp3
conf qosprofile egress qp1 minbw 0 maxbw 20 ports 10,14,15
conf qosprofile egress qp3 minbw 0 maxbw 80 ports 10,14,15
<!--EndFragment-->
(from Joshua_Winchell)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Mar 21 2012 5:09PM
Imp thing to understand here is that by setting the maxBW you arae restrciting the BW to not go more than 80 or 20%. In this case you are not using you BW correctly I believe.
What you can do is. Create a single Qos profile for non-vital traffic and set the max BW to 20 for it so that under any circumstance that VLAN won't use more than20% of the BW and then apply the QP to that VLAN and let other VLAN be in the default setting which would allow it to occupy 100% of BW if required.
So basically the vital VLAN gets 0-100% of BW
and non-vital gets 20% (max)
Let me know what works out for you.
(from Arpit_Bhatt)
