Question about EAPS in XOS
  • Question
  • Updated 2 years ago
  • Answered
Is there a way to delay or put a hold timer in place when downed links are repaired and come back up?  We need to be able to control port flaps as fiber is repaired on very large EAPS rings... 1200 or so vlans all ten gig interfaces.  EAPS works great when we get a cut but if fiber splicers have issues and cause brief duration multiple port flaps this affects many customers using a routed service and their routers have issues getting the agency back stable... What should be a 50 to 100 ms hit turns into a 4 or 5 minute outage... On RPS or 8032 rings there is a holdback timer that can be set but I cant seem to find anywhere you can do this on an EAPS ring...
Photo of EtherMAN
EtherMAN, Embassador
  • 6,456 Points 5k badge 2x thumb
Posted 2 years ago
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
Hi, I don't see any specific command to delay the EAPS restore action.
Since that takes place when Master node receives the EAPS health-check message I'm wondering if increasing the EAPS hello time could help. However, that will also affects the failover time and also it's not 100% accurate since the hello packet can be sent by Master node before the link is repaired.
An option would be using a higher EAPS hello time (that will be also used for EAPS restore action) and apply CFM configuration so you can have the standard failover time.
Maybe a lab could help to confirm if that works.
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
I agree with Henrique suggestion, CFM with EAPS + longer timers might work.
However, I agree, it would be a good feature for EAPS to have a non-revertive mode and a wait-to-restore timer like ERPS.
Let me get a feature request opened up for this, and I'll come back with the feature request number.
-Brandon
I just created feature request 01237407 for this.
Etherman, I would suggest checking in with your account team regarding this feature as well.
Photo of EtherMAN
Thanks guys as always.  You quickly confirmed what I though was true... Now the question is whether to convert my EAPS rings where i have known users that have routers being affected by this to ERPS rings.
As much as I like EAPS and its simplicity, sometimes ERPS is the better solution, especially in a service provider environment.
I would expect it to be fairly painless to convert from EAPS to ERPS. You could bring up the ERPS ring with its own control vlan and no protected vlans, then move protected VLANs over individually once you are satisfied that ERPS is working correctly.
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,592 Points 10k badge 2x thumb
To my (little) knowledge this feature has been on the table but never implemented. A FR is the best approach here.
