RAM and in-built storage (Internal HDD, CF etc) and external CF?
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
Hi, The title is self explanatory. I need commands to check the internal storage (hard disk, internal compact flash etc) and external compact flash for all platform running EXOS in order to find out the total size, in-use and available etc.
Thanks
Harkanwal
Photo of Harkanwaljeet Singh
Harkanwaljeet Singh
  • 674 Points 500 badge 2x thumb
Posted 2 years ago
Photo of David Choi
David Choi, Employee
  • 1,966 Points 1k badge 2x thumb
Please issue "fdisk -l" command after entering debug-mode. To enter debug-mode, you need a debug mode password which you can get it from GTAC. Below is a sample output of it.
* SW1.1 # enable debug-mode
EXOS version: 15.3.1.4
System MAC : 00:04:96:37:3B:9F
Challenge  : kL3yMw7pIK*SFdFSntN%QjX6pIuw+J0HU6EQ8VIF/jmh8cTLEMvrsDtjRfPL3VCLg
             TVPpj3JfpkECq91Gep8VVpcWdqySeg9C0qnGYmUGRtz/8PiiiauSJLZEE4PNiiFn0
             DeueN6Xr3I%iC5Dbs/deMJh51EypML4vyKLUMgjV535tHAcZx/Qhyyg*E9dQufzqV
             E1CEVEDT%A*E8YPL/pve%x1NPt%%88kz%2cc4i/zL3DvoonUIpd4TiQDqeyTiQi*5
             3az5aLJHZGzSF+7Uj87fBIBkrYHeEiMJH7oR4/t*dr2oo4SJWgJ08/vIYS7EN5CRa
             *6IHvzB%B7CcjQeXQ==
NOTE: The password you received will only be valid for another 59 minutes.
Enter debug mode password:
* (debug) SW1.2 #
2. Enter a command "!fdisk -l"
* (debug) SW1.3 # fdisk -l
Disk /dev/hda: 262 MB, 262930432 bytes
16 heads, 32 sectors/track, 1003 cylinders
Units = cylinders of 512 * 512 = 262144 bytes
   Device Boot      Start         End      Blocks  Id System
/dev/hda1   *           1          81       20480+  6 FAT16
Partition 1 does not end on cylinder boundary
/dev/hda2              81         161       20480+  6 FAT16
Partition 2 does not end on cylinder boundary
/dev/hda3             161         977      208962   5 Extended
Partition 3 does not end on cylinder boundary
/dev/hda5             161         441       71680+ 13 Unknown
/dev/hda6             441         721       71680+ 13 Unknown
/dev/hda7             721         785       16384+ 13 Unknown
/dev/hda8             785         977       49152+  6 FAT16
* (debug) SW1.4 #
If you insert additional CF memory into this MSM, then you will see another “Disk /dev/had” in the output (In above example, there is no additional CF memory inserted)
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,784 Points 10k badge 2x thumb
Isn't a "ls" not enough? and a "sh mem" for RAM.
* Leaf1.1 # ls
drw-r--r--    2 root     root         1024 Oct 12  2015 dhcp
-rw-r--r--    1 admin    admin        2877 Apr 19  2015 eventd.pol
-rw-r--r--    1 admin    admin       10083 Mar 15  2015 eventd.py
-rw-r--r--    1 root     root         9078 Mar 15  2015 eventd.pyc
-rw-r--r--    1 admin    admin         927 Jan 18  2016 l2pbr-from-net.pol
-rw-r--r--    1 admin    admin         888 Jan 18  2016 l2pbr-to-net.pol
drw-r--r--    2 root     root         1024 Oct 12  2015 lost+found
-rw-r--r--    1 admin    admin       21298 Jun 30 18:45 nms.xsf
-rw-r--r--    1 root     root       292671 Aug  3  2015 old_non_stack.cfg
-rw-r--r--    1 root     root      1226049 Jul 13 22:26 primary.cfg
-rw-r--r--    1 admin    admin          33 Mar 20  2015 pyshell.py
-rw-r--r--    1 root     root       443717 Feb 17 10:34 secondary.cfg
-rw-r--r--    1 admin    admin         344 Mar 15  2015 setup.xsf
-rw-r--r--    1 admin    admin        3454 Mar 15  2015 shell.py
drwxr-xr-x    2 root     root         1024 Jul 14 08:10 vmt
 1K-blocks      Used Available Use%
    181576      7648    173928   4%
* Leaf1.2 #
* Leaf1.2 #
* Leaf1.2 # sh memory
System Memory Information
 Total DRAM (KB): 2097152
 System     (KB): 76264
 User       (KB): 364700
 Free       (KB): 1656188
Harkanwaljeet Singh
Hi David,
Thanks for the update. But surprisingly, I did not find it any impressive to keep dependency on TAC for these simple things.
I have few commands as below:
1) "show memory", "top" etc commands are there for memory.
2) "show memorycard", i believe, is for the external compact flash. If yes what is the internal-memory storage capacity then (e.g. for BD8806 with MSM48c)
"ls" is showing in 1K-blocks and I am not sure if it is 512-bytes or what?
From the below output of "ls" ; shall I consider that the internal-memory is 8 MB.
     16384       636     15748   4%
Regards,
Harkanwaljeet Singh
Photo of David Choi
Hi Harkanwaljeet,
1) "show memory" shows system memory information in other word, system DRAM. You can see total DRAM and free from the output. In case of MSM128, it has 1G DRAM so:
(debug) BD6.4 # sh memory
 MSM-A    Total DRAM (KB): 1048576
 MSM-A    System     (KB): 40152
 MSM-A    User       (KB): 304000
 MSM-A    Free       (KB): 704424
 MSM-B    Total DRAM (KB): 1048576
 MSM-B    System     (KB): 40152
 MSM-B    User       (KB): 316716
 MSM-B    Free       (KB): 691708
You can see total DRAM as 1GB and Free memory is 704MB.
2) "show memorycard" shows external USB memory (maybe CF card if it was old model). But it seems the output of this command doesn't show the size of external memory.
BD-X8.1 # show memorycard
Memorycard is present in USB-1.
So to see the size, you need to execute "fdisk -l" command in debug-mode as I mentioned.
3) "ls" just shows a portion of "/usr/local/cfg" directory and "ls internal-memory" also shows a portion of "/usr/local/tmp" directory.
     16384      6268     10116  38%
     49038       580     48458   1%
I believe 1K-blocks means 1024. Therefore, I think the size of "ls" is about 16M and "ls internal-memory" is about 50M.
Photo of Drew C.
Drew C., Community Manager
  • 38,410 Points 20k badge 2x thumb
An article was written that helps to explain this topic:
How to check free memory and disk space in EXOS
