Radiation pattern/data sheets for all external antennas of AP3715e
  • Question
  • Updated 4 years ago
Searching for data sheets and radiation pattern of all available external antenna types for AP3700e series access points. Specially more detailed information for the triple feed sector antenna with 120 degree beamwidth. Needed for probly design a new wirless infrastructure (industriel environment).
Where can I download the data sheets?
Photo of Hartmut Sachse
Hartmut Sachse
  • 2,598 Points 2k badge 2x thumb
Posted 4 years ago
Photo of Aguilar, William
Aguilar, William, Employee
  • 2,664 Points 2k badge 2x thumb
There is no datasheet for each antenna, however, the radiation patterns and specs for most of the antennas are included in the Site Preparation and Installation Guide. We are in the process of updating the document to add newer antennas and APs but it should have the information you seek for the 120deg.
The URL for the document can be found here:
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-are-external-Antenna-line-of-sight-dista...
Thanks,
Wii
edit: Updated to use GTAC Knowledge link
(Edited)
Hartmut Sachse
Thanks, I would take a look at the installation guide, but for future it would be great if Extreme provide full specs of all antenna types. Also would be great if you send the required information to Ekahau so they could include it in there next ESS release for use during predictive site surveys.
