Radius Test
  • Problem
  • Updated 3 years ago
  • In Progress
Good morning, i configured Radius server on V2110. radius server is based on Windows 2008 R2.
All seems is working but when I try to connect to radius, under wlan service --> test, I received an error. Access rejected.
Photo of Giuseppe Montanarella
Posted 3 years ago
Photo of Philipp Tittmann
Philipp Tittmann
  • 774 Points 500 badge 2x thumb
Hi Guiseppe,
on Windows Server, did you install the active directory certificate authority? I think you need this Windows Role too, and of course a valid server certificate.
best regards
Photo of Jason
Jason, Employee
  • 3,534 Points 3k badge 2x thumb
Hello Giuseppe,
If you are receiving an "Access Rejected" error, then that is good. The test button in the WLAN Service is designed to test the communication to Radius and not authenticate a user.  There are no credentials passed to radius only a test user name that is expected to receive an error.
thank you, but in Windows 2008 the Standard Configuration is NPA or 802.1x ?
Photo of Hartmut Sachse
Hartmut Sachse
  • 2,528 Points 2k badge 2x thumb
Hello Giuseppe,
the default configuration of NPS ist empty. You have to define network policies to use authentications like PEAP or EAP-TLS for wireless clients. Or a policy to use PAP if you use external captive portal authentication. Don't forget to setup a radius client first with the right shared secret or every RADIUS request will be reject by the authentication server.
If you want setup PEAP or TLS you have make sure that a service certificate is installed (useable for serverauth). For more information search inside the MS knowledge base.
Best Regards,
