Rate Limiting with Timer on Extreme
  • Question
  • Updated 3 years ago
  • Answered
Hello Community,
Have some of you configure Rate limiting with Timing on Extreme Networks Switches?
We have a customer who is going to migrate from Cisco to Extreme , they are an ISP that use Rate Limiting with timing on their clients , they want to provide all day 10MB from monday to friday and 15MB on weekends . This is an example that i found from cisco :
time-range DAILY-0900-2100
periodic daily 7:00 to 21:00
ip access-list extended ACL-0900-2100
permit ip any any time-range DAILY-0900-2100
ip access-list extended ACL_ALL_HOURS
permit ip any any
class-map match-all 256K
match access-group name ACL-0900-2100
class-map match-all 1M
match access-group name ACL_ALL_HOURS
policy-map POLICY-IN
class 256K
police 256000 8000 exceed-action drop
class 1M
police 1000000 12500 exceed-action drop
So How to configure rate limiting with timing on Extreme Networks Switches?
Thanks .
Photo of Marlon Porras Carazas
Posted 3 years ago
Photo of Jarek
Jarek
  • 2,398 Points 2k badge 2x thumb
I see that you have policy-map policy-in, but:
- do you need rate limit egress and ingress or only ingress ?
- do you need rate limit on port or on vlan ?
- or maybe rate limit per IP address ?
You can use for example: meter + ACL + upm script.
Jarek
(Edited)
Photo of Drew C.
Drew C., Community Manager
  • 40,690 Points 20k badge 2x thumb
You may also be interested in this thread, which should give you some ideas on how UPM scripting works.
https://community.extremenetworks.com/extreme/topics/poe-scheduling-upm-profiles
