Re-direct Guest users to a website after accepting Terms and Condititons ?
  • Question
  • Updated 6 months ago
  • Answered
How do you set up a process whereby wireless Guest users are re-directed to a url e.g www.extremenetworks.com after accepting terms and conditions on the captive portal ?
Photo of Siobhan Stynes
Siobhan Stynes
  • 150 Points 100 badge 2x thumb
Posted 7 months ago
Photo of Christopher Frazee
Christopher Frazee, Employee
  • 2,258 Points 2k badge 2x thumb
Hello Siobhan,
      You did not detail what WiNG 5 device, but if using a wireless controller (e.g. NX, VX, RFS) or access point that supports this feature, you will use the following via the CLI:
enable [enter]
config [enter]
captive-portal xxxxxx [enter] (x represent captive portal policy. You can use tab key to auto-fill the name. If typing, capitalization matters with names)
webpage-location advanced [enter]
webpage external welcome xxxxxxxx [enter] (x represents complete URL)
webpage internal welcome use-external-success-url [enter]
com wr [enter]
Siobhan Stynes
Thanks Christopher.  We are using a AP7522 in VC mode. Entering the CLI commands you suggested , we get a 404 error
Photo of Michael (Misha) Elin
Michael (Misha) Elin, SE
  • 538 Points 500 badge 2x thumb
captive portal hotspot
 webpage external welcome http://in.the.middle
Siobhan Stynes
Thank you
Siobhan Stynes
That works for laptops and PC's but the the re-direct does not work on mobile devices?  Any ideas why ?
Photo of Andrew Blomley
Andrew Blomley, Employee
  • 1,042 Points 1k badge 2x thumb
in the captive portal select Redirect the user to externally-hosted success URL
select externally hosted
add the URL
Siobhan Stynes
Thanks Andy, we have been doing this however there is no option to select ok ...its greyed out ??
We thought we were missing a previous step.
Photo of Darrel Rhodes
Darrel Rhodes, Employee
  • 1,186 Points 1k badge 2x thumb
Hi Siobhan, I believe you need an entry in all of the the URL fields before the OK button becomes available.
