Reassign Advanced Edge License
  • Problem
  • Updated 2 years ago
  • Not a Problem
Hi everyone, I've a problem is I activated Advanced Edge License on a X460, and now how do I do to reassign this license to another X460? Thank you very much.
Photo of Quang Vinh Trinh
Quang Vinh Trinh
  • 130 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Magda Cabral
Magda Cabral
  • 60 Points
ok Friend ́s work!Congratulations!Thaks a lot!
Photo of Vellachery, Sumeesh
Vellachery, Sumeesh, Employee
  • 3,288 Points 3k badge 2x thumb
Quang
Vinh Trinh,
what is the serial# of the x460 switches? From which serial# to which serial# you would like to move? Is it from a defective switch serial# you would like to move it to a replacement unit?
Regards,
Sumeesh.v
(Edited)
Quang Vinh Trinh
I've activated on switch serial is 1348G-00240. The replacement switch hasn't been determinated. I mean is deactive license to reserve.
Photo of André Herkenrath
André Herkenrath, Employee
  • 1,962 Points 1k badge 2x thumb
This just works in case of a RMA - The license conditions of Extreme Networks do not allow to move licenses from one box to another.
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,594 Points 10k badge 2x thumb
Adding to what Andre said, if an RMA is processed you are provided a new voucher number to be installed on the replacement ship. If the switch is being replaced before the RMA is processed GTAC may be able to make an exception and transfer the license.
