Reference firmware not "checked" after updating X690s to latest reference firmware in EMC 8.1.3.65
  • Question
  • Updated 2 months ago
Hello.  In Extreme Management Center (EMC formerly Netsight) version 8.1.3.65, in the devices section we have 18 various pieces of network gear from Cisco to Extreme listed.  In the firmware section I have specified the latest Summit and onie 22.5.1.7 as the "reference" firmware.  This past weekend I upgraded two X690 stacks which run our core network.  The upgrade went smoothly using EMC but what is interesting is I don't have a checkmark in the reference column despite the firmware now listed as 22.5.1.7.  I have some Cisco switches with Cisco IOS firmware set as reference image and the Cisco devices on that firmware version that I have set as reference all have a check mark in the column.
Its not a huge deal, but it is nice to have this column working because at a glance you can see if your gear is up to the latest code level you declared as reference for your environment.  Is it a bug, or am I misunderstanding what this column is used for?
Photo of kjstech
kjstech
  • 624 Points 500 badge 2x thumb
Posted 2 months ago
Be the first to post a reply!
