Regular LAG in a MLAG config
  • Question
  • Updated 5 years ago
  • Answered
Create Date: Jul 17 2013 10:52AM
There are 2 core switches and two edge switches.
There is an ISC Link between the core switches.
The Edge Switch should be connected via "Regular LAG" to both cores through port 1 and port 2.
CONFIGURING MLAG "Edge on two Cores"
Does it mean we should configure Port Sharing an the Edge line this?
enable sharing 1 grouping 1,2
There is only ONE Port "1" on the Edge later.
There is no Port 2 on the Edge later.
CONFIGURING MLAG "Core on two Edges"
Because of the shared Port 1(1+2) there is no chance to configure it.
(from roman@krakovic.de)
Photo of EtherNation User
EtherNation User, Employee
  • 20,350 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Aug 1 2013 10:18AM
That's correct, after port grouping You use only group port 1.
(from karpiu)
Create Date: Sep 7 2013 2:43AM
Two-tier MLAG Implementation Guide...
https://www.dropbox.com/s/pb4qsdzis05...
(from Daniel_Flouret)
