regular LAG in a MLAG environment
  • Question
  • Updated 5 years ago
Create Date: Jul 17 2013 11:02AM
There are 2 core switches and two edge switches.
There is an ISC Link between the core switches.
The Edge Switch should be connected via "Regular LAG" to both cores through port 1 and port 2.
CONFIGURING MLAG "Edge on two Cores"
Does it mean we should configure Port Sharing an the Edge line this?
enable sharing 1 grouping 1,2
There is only ONE Port "1" on the Edge later.
There is no Port 2 on the Edge later.
CONFIGURING MLAG "Core on two Edges"
Because of the shared Port 1(1+2) there is no chance to configure it.
(from Roman)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Jul 19 2013 3:51PM
Hey Roman
I am sorry but I need more information.  You are correct that the edge needs to set up a regular LAG.  From the post you are taking port 1 to core 1 and port 2 to core 2.  The MLAG is setup differently on the core.  You need to set up the MLAG peers and then the Peer ports where you will set port 1 on core 1 to port 2 on core 2 as a peer.
I hope that helps if I am still unclear please provide more information and/or a diagram.
P
(from Paul_Russo)
