Remote APs - Captive portal
  • Question
  • Updated 3 years ago
  • Answered
I have remotes APs and I want to set an SSID with a captive portal for guest access, but the Internet traffic should be from the local Internet connection where are the APs, not where the controller is located.
It's possible ?
Photo of agd
agd
  • 382 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,884 Points 20k badge 2x thumb
Yes, that is possible.
Set the topology for the non-authenticated role to either routed or bridge@EWC (traffic thru the controller) and as soon as the client has put in username/password he'll get the authenticated role.
For this role use a bridge@AP topology.
Here a "normal" example...
https://community.extremenetworks.com/extreme/topics/how-to-identifi-wireless-appliances-guest-porta...
So just change the topology in the "2) create roles" section.
!!! you should use a very low DHCP lease time on the first toplogy, so if the client is switching roles/topology that he'll renew his IP !!!
-Ron
Photo of Laura
Laura
  • 1,490 Points 1k badge 2x thumb
I think I am trying to create the same thing, if this is what it does:...this captive portal lets guests users logon to a guest SSID and only be able to access the internet, not our other network resources?
Hi Laura,
Yes, if you configure it per the above example you should be fine.
If you don't use a dedicated firewall for guest access (= the FW is also used for your internal network) make sure to create rules on the firewall to deny traffic from the guest VLAN to the intranet interfaces/resources.
-Ron
Photo of Laura
Laura
I am just confused on what IP addresses to use, since I am not very familiar with our network. I will need to find out my default gawteway and dns servers, correct? the rest I just create on my own?
TheĀ easiest and most secure way (guest can't access intranet) is to connect the controller directly via a unused port to a unused port on the firewall.
The FW is the default gateway and you could use the Google DNS 8.8.8.8 & 8.8.4.4.
