Remote mirroring and LAG on Summit X460
  • Question
  • Updated 3 years ago
  • Answered
I have two switch sw1 and sw2 connected using LAG. I have to organize rmirror for some ports on sw1. My sniffer is connected to an access port on sw2.   I read the next statement in the ExOS Concept Guide:
 In normal mirroring, a monitor port cannot be added to a load share group. In one-to-many
mirroring, a monitor port list can be added to a load share group, but a loopback port cannot be
used in a load share group.
So I can not understand is there any way to it? May be I have to organize another link between switch?
Photo of Roman
Roman
  • 100 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Martin Flammia
Martin Flammia
  • 6,326 Points 5k badge 2x thumb
Believe there is a way to configure what you are asking but there might be a simpler solution for you, as you can do a packet capture directly on the switch and then tftp that off to view in your sniffer - if that's you intention.
Used it myself many times, restricting to so many packets and works great!
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-perform-a-local-packet-capture-on-an-EXOS-switch
Photo of Bernardo Valladares
Bernardo Valladares, Employee
  • 184 Points 100 badge 2x thumb
Hey Martin, so doing a remote mirror through a lag port is not possible? Your alternative would be the only way?
Martin Flammia
Hi Bernardo, can't really comment on experience but my understanding is that you can't add a load share group as a mirror port but I don't see any reason you couldn't do a remote mirror via / through a lag (load share group) port.
http://documentation.extremenetworks.com/exos/EXOS_All/Slots_and_Ports/c_summit-family-switches.shtm...
Heres a post that might be helpful:
https://community.extremenetworks.com/extreme/topics/remote-mirroring-trunk-lacp
Hopefully someone else will comment if I have this wrong. Thanks
(Edited)
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Roman....really sorry to see it took us 12 months to get back to you on this!  I'm hopeful you'll give us another chance as strength of the Hub Community has grown significantly in the last 12 months.
Martin, thank you so very much for reviving this thread and offering a proper path to answering Roman's question.
Today is a new day on the Hub thanks to our great community members like Martin.
