Removing 48 port from stack, and adding two 24 ports
  • Problem
  • Updated 3 years ago
We have had a failure with a X250e48p, and we now have to add two X250e24p switches to the stack asap.    What is the correct process to achieve this,  I am aware that if we just re-add a 24 port then the configuration will remember it was a 48 port.    Does anybody have any documentation or notes to achieve this.
Photo of deanj_hull
  • 70 Points
Posted 3 years ago
Photo of Edson Yuji
Edson Yuji
  • 212 Points 100 badge 2x thumb
1. Run the "show configuration | i <SLOT NUMBER>" command to backup the slot switch with problems;
2. Command "unconfigure slot <SLOT NUMBER> module";
3. Command "configure slot <SLOT NUMBER> module X250e-24p";
4. Return config the switch.
