replacing faulty summit x250e with new Summit x440 into existing summit x250e stack (same firmware)
  • 2
  • Question
  • Updated 3 years ago
  • Answered
Dear All,
My existing network is running with all summit x250e with stacking. I understand that Summit x250e is already end of life and not able to purchase. So I am looking at replacement model which is Summit x440. I would like to know that how can I replace new Summit x440 into existing Summit x250e stack if one of the summit x250e switch is failed without rebooting the whole stack?
The existing config for faulty Summit x250e will synchronize automatically to the new replacement Summit x440 switch? Or I need to reconfigure the port assignment for new Summit x440 switch?
Appreciate your suggestion.
Thanks.
Minn Htet
Photo of Soe Minn Htet
Soe Minn Htet
  • 120 Points 100 badge 2x thumb
Posted 3 years ago
  • 2
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,362 Points 4k badge 2x thumb
if you add a different model switch to an existing stack it will not load the config for that slot.
Its better you reconfigure that slot.
Photo of andreas
andreas
  • 1,218 Points 1k badge 2x thumb
backup your Current config remove the slot. Unconfigure the slot. Add the new slot and restore the port specific config.
Make sure you have a New enough version to support x440.
Photo of Johan Hendrikx
Johan Hendrikx
  • 3,040 Points 3k badge 2x thumb
Be aware that the summit x250 have 26 ports and the x440 have 24 ports
You must also change the type of module for that slot you are replacing the switch
Soe Minn Htet
Dear All,
Thank you for all your feedback and it's really helpful to me. So in this case, I don't need to reboot the entire x250e stack switches right?
- I just need to backup the current configuration
- Remove the faulty x250e switch
- unconfigure the slot that was used by faulty x250e
- Add new x440 and synchronize from master switch as follow
1) synchronize stacking node-address "xx:xx:xx:xx:xx:xx" (new x440 mac address)
2) configure stacking node-address "xx:xx:xx:xx:xx:xx" slot-number xx
3) reboot node-address "xx:xx:xx:xx:xx:xx"
- Reconfigure the recently added x440 switch as per new slot number
Anything that I miss out ? :)
Regards,
Minn Htet
Photo of Zelnosky, Kevin
Zelnosky, Kevin, Employee
  • 1,124 Points 1k badge 2x thumb
You may need to also do a "enable stacking node-address xx:xx:xx:xx:xx:xx" before the reboot to get it to come up as an active member of the stack.
Also be aware that when mixing Summit switch models in a SummitStack, all nodes will only be able to operate at the capacity of the weakest member.  This means that if you have a more robust switch and stack it with a less capable switch, the more robust switch will use the same table sizes as the weaker member, etc.
Photo of De Wet Hoffman
De Wet Hoffman
  • 60 Points
We are in a similar situation and also looking at replacing the X250's with X440's. Could you re-use the Gbic's and stacking cables from the X250's with the X440's?
Photo of Drew C.
Drew C., Community Manager
  • 37,362 Points 20k badge 2x thumb
Yes, that should be just fine.
