RFS6000 ---- CPU load averages : 1 min: 99.9% 5 min: 99.9% 15 min: 99.9%
  • 2
  • Problem
  • Updated 9 months ago
  • Not a Problem
Hello,
We have a RFS6000 WIFI controller and currently I have 100% processor load.
- service show diag stats :
Processor use by processes seems correct.
- service show diag top
 PID  STATUS   RSS  PPID %CPU %MEM COMMAND
 1206  S        29M  1205  0.0 11.9 ccsrvr
 1330  S        22M  1329  0.0  8.8 securitymgr
 1227  S        10M  1226  0.0  4.3 ccstatsd
 1391  S       7280  1390  0.0  2.8 rnsd
 1172  S       6768  1171  0.5  2.6 snmpd
 1368  S       5944  1365  0.0  2.3 dpd
 1423  S       4632     1  0.0  1.8 imi
18406  S       4360 18404  0.0  1.7 imish
 1235  S       3764  1234  0.0  1.4 fileMgmt
 1187  S       3592  1186  0.0  1.4 CertMgr
I do not understand the cause of this processor overhead !!!
Someone can help me
Thank you
Photo of YAZID
YAZID
  • 100 Points 100 badge 2x thumb
Posted 9 months ago
  • 2
Photo of Shay Weir
Shay Weir
  • 1,648 Points 1k badge 2x thumb
We had the same thing happen to us about a week ago.  Still waiting on the Root Cause.  We ran the "service show process" command and saw the CFGD process taking 99% for more than 24 hours.  So far Support is saying a script was running and got hung up.  Like I said though, we are still waiting on the root cause after we uploaded all tech-support files before reloading the controller.  Since the reload, all has been good.
Suggest you get a case open before you reload and do a "service copy tech-support ftp://xxx.xxx.xxx/file-name to a local drive.  When you open the case you can upload the tech-support file for them to analyze.
Photo of YAZID
YAZID
Hello Shay Weir;
Thank you for your prompt response. Indeed, for my case, all the processes work correctly and I do not see a process that uses much processor !!!!
Photo of Chris
Chris
  • 160 Points 100 badge 2x thumb
Is there any scraping that goes on in the background for information on devices the RFS is controlling? We had an issue where all 150 of our devices were being scraped by an external process which would login and run a script every X amount of seconds. I would also have a look through the best practices which goes into some causes of high CPU load: http://documentation.extremenetworks.com/WiNG/Implementation_Guides/WING5X_Reference_Best_Practices_...
Photo of Christoph S.
Christoph S., Employee
  • 2,590 Points 2k badge 2x thumb
What version of firmware is the controller on?
Here's a link that might help: High CPU Utilization of process cfgd on WM3000 controller
Photo of YAZID
YAZID
Hello Christoph S;
        Below the result of the "show version"
        RFS6000 version 4.4.1.0-008R MIB=01a
        Copyright (c) 2006-2011 Motorola Solutions, Inc.
        Booted from secondary.
        switch uptime is 540 days, 9 hours 39 minutes
        CPU is RMI XLR V0.4
        255476 kB of on-board RAM
Cordially;
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 4,062 Points 4k badge 2x thumb
You are running firmware WiNG 4.x the above kb article does not apply. KB states that in firmware WiNG 5.5 CDP is enabled by default, while in earlier versions CDP was disabled by default.
  • 4,082 Points 4k badge 2x thumb
Yazid please contact GTAC on the phone or you can use the Extreme Portal to open a case.
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
