RIght NAC interfaces configuration for DHCP Snooping
  • Question
  • Updated 8 months ago
  • Answered
Hello, everybody,
I had a succesfull experience on bringing PC's OS data to Netsight. (It could be seen in Control >> End systems).
NAC snoops DHCP data in VLAN and (after time-consuming sophisticated configuration) sends it to Netsight. (Where identity-management is also configured).
But it was made for Default VLAN 1 and DHCP server was in the same VLAN.
I want now to configure the same thing but in company where dozens vlan exists and all of them gets IPs by bootp-relay feature from Windows Server.
My question is: what is proper configuration for a NAC interface? Bring all trunks to it?
Please, advice me something correct.
Many thanks in advance, Ilya
Photo of Ilya Semenov
Ilya Semenov
  • 4,610 Points 4k badge 2x thumb
Posted 11 months ago
Photo of Yacobucci, Ryan
Yacobucci, Ryan, Multi-Tier Technical Support Engineer
  • 5,322 Points 5k badge 2x thumb
Hello,
You should be able to configure the network routers with an additional DHCP helper that is pointed to NAC.
DHCP helper 1 points to real DHCP server
DHCP helper 2 points to NAC
The Router should send the DHCP discover/request packets to both the real windows DHCP server and the NAC appliance to perform DHCP snooping.
Thanks
-Ryan
Ilya Semenov
Thanks, I will try to do that.
Ilya Semenov
Hi, Ryan, I did as you'd said and it works perfectly well. Many thanks to you!
