Roaming is not working with devices that connect to the 2.4 band
  • Problem
  • Updated 2 years ago
  • Not a Problem
  • (Edited)
Roaming is not working with devices that connect to the 2.4 band, which they believe may be happening APs I have are 3715i
Photo of Jesús Flores
Jesús Flores
  • 70 Points
Posted 2 years ago
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
What version of code?
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,588 Points 5k badge 2x thumb
Hi
Could you clarify what you mean by roaming doesn't work, do you mean the client isn't roaming to another closer AP as you expect it to, or that after roaming, the client isn't connected?
-Gareth
Photo of Umut Aydin
Umut Aydin, Escalation Support Engineer
  • 2,290 Points 2k badge 2x thumb
Are all Wireless Clients affected?
OS Version..driver version of the clients..
All VNS /Topology Type affected?
Could you do the test with a different AP Type?
Photo of Drew C.
Drew C., Community Manager
  • 39,446 Points 20k badge 2x thumb
Hi Jesús, do you still need help with this issue?  If so, can you please share the details requested in the replies above?
