Roaming issue.
  • Problem
  • Updated 11 months ago
  • Solved
Hello Friends.
Could you help mi with small issue. I have a RFS400 with 8 AP-6521.And i have some problem with that.
Peaople from werehouse work on terminal(gun) with remote destop and sometie when they walk around werehosu wen switching beetwen AP they lost connection to remote destop for 30 sec some time it is happen some times not. ON RFS and AP is WING 5.8.6.0-11R
I have no Idea what is going on. Could you help me?
Photo of Kamil Mazur
Kamil Mazur
  • 132 Points 100 badge 2x thumb
Posted 11 months ago
Photo of Timo
Timo
  • 3,210 Points 3k badge 2x thumb
do you check the event-history for messages? show event-history via CLI.
What typ of scanner do you use? Motorola/Symbol/Zebra, check for fusion logs.
What typ of encryption/authentication do you use?
Photo of JESUS REYES DIAZ
JESUS REYES DIAZ
  • 222 Points 100 badge 2x thumb
1.- can you check ROSSI on móvil device? Problema with converge?
2.- AP6521 Is a level entry device for a warehouse, then you should take a site survey .
3.- AP with antennas External ?
Photo of Ignace Vyncke
Ignace Vyncke
  • 210 Points 100 badge 2x thumb
hi, have you looked at your channel's on different AP's, is smart-RF enabled or not ?
Photo of Bin
Bin, Employee
  • 5,372 Points 5k badge 2x thumb
Hi, Kamil
Add the following article for your reference.
why do my wireless clients not roam properly?
https://gtacknowledge.extremenetworks.com/articles/Q_A/why-do-my-wireless-clients-not-roam-properly
Best regards,
Bin
Kamil Mazur
Hello,
Today on my werehous was for couple hours ok, then again 30-60sec dealy on rdp conecction.
I forgot to mention thaht when it was configured on virtualControler there was no problems
Hello Timo,
Yep but it is nothing i thing. I go again with that and send logs tomorow. Maybey you will see with that.
We use Motorola MC9100, i checked fusion logs and everything is ok enitaime connected to MAC (ap) and coneccted to network so i think is ok.
wlan xxx
 ssid xxx
 vlan 1
 bridging-mode tunnel
 encryption-type ccmp
 authentication-type none
 wpa-wpa2 psk 0 password
 wpa-wpa2 exclude-wpa2-tkip
Hello, Jesus
This was configured firstyl as VC at commpay external and it was working perfect.
What is ROSSI?
External
Hello Ignace,
Yeah I use 1,6,11 channels with smart-rf
Hello Bin,
I need to go with check this tomorrow.
It is weard thing like today work perfectly couple haours and then some problems.
I am still seachring the problem.
Thanks friends.
Photo of Richard Muehlberger
Richard Muehlberger
  • 200 Points 100 badge 2x thumb
hi kamil,
is it only rdp?
what about a permanent ping, does it fail too?
30 seconds sounds like spanning tree
so
- ensure that there is no loop over the rfs4k
- check the log of the backbone switch
nr
richard
Kamil Mazur
Hello guys.
Thanks Richard.
I found the reason, it was 2 switch Connect double (on lan and fibre channel) on AP side. I correct this and problem dissapper.
Thanks for your help.
