routing between vlan on B5 (ip routing command)
  • Problem
  • Updated 3 years ago
  • Solved
Dear,
   I Have on Enterasys B5G124624 switch, (FW: 06.71.03.0025, HW : BCM56514 REV 1, Bp : 02.02.51), when I enable routing inter vlan, using command ip routing, the switch accept command,, but I don't see it in configuration ( output of command show conf) and also there's no routing between my vlan.
   I have a same problem in other switch.
  Could you help me with this issue?
   Thank you.
best regards
Hamid
Photo of Hamid ABOU ABDALLAH
Hamid ABOU ABDALLAH
  • 100 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Christoph
Christoph
  • 1,842 Points 1k badge 2x thumb
ip routing is enabled by default, so in config you will not see an entry.
Make sure, your IP interfaces are enabled (no shutdown). For troubleshooting, first try to ping the interfaces from inside the router mode. If this works, try to ping the interfaces of the B5 from connected hosts.
Hamid ABOU ABDALLAH
Hi Christoph,
    Thank you for your reply.
    I find an issue, it's my mistake, I don't set port to vlan.
   Thank you again.
best regards
Hamid
