Routing Tip for Switch 220 Series
info_systemhaus
New Contributor II
how to configure Routing Between VLAN's on a 220 Series Switch.
I have a new 220 Series Switch and i have configured 2 VLans ( 100 + 200 )
Every VLAN is Routing enabled and has the IP . 192.168.100.1 /24 and 192.168.200.1 /24
The Internet Gateway is on the VLAN 100 with the IP 192.168.100.254/24
I have a DHCP Server activatet and created a pool for the VLAN 200. The Gateway for DHCP Clients was set to the VLAN IP . 192.168.200.1/24
When i connect a PC on a Port that is Untagged into VLAN 200, the PC get his IP Adress
..example 192.168.200.14/24 with Gateway 192.168.200.1
At the end i have created a Default route with :
0.0.0.0 0.0.0.0 192.168.100.254 (Internet Router) VLAN 100 (next Hop Interface)
Result: from a PC into the VLAN 200 i can ping his own Gateway and i can ping the Gateway of the VLAN 100 ... but i can not ping an other address into VLAN 100 and i can not ping a public IP.
The packets will be routet but only to the Gateway of the next vlan into the Switch . and they will not leave the Switch ...
Where is my Brain Block ... 
Perhaps, someone of you has already made some Routing games with the 200 Series....
Regards
Christian
2 REPLIES 2
info_systemhaus
New Contributor II
Hi Mate,
many thx .. that was my brain blocker .. it was to late yesterday.
I configured the reverse route from Internet router and all was fine.
Chris
Andre_Brits_Kan
Contributor II
Hi
You are misaing your reverse route from the gateway.
On 192.168.100.254 to get to the 192.168.200.x network goto 192.168.100.x. x would be the vlan 100 interface on your 200 series switch.
Hope this helps
