Routing between VLANs
  • Question
  • Updated 5 years ago
  • Answered
Create Date: Jul 13 2013 1:09PM
I am trying to get two VLANs which are configured in the same switch to communicate between each other. To my understanding, the switch can do layer 3 routing between VLANs that are configured in the same switch with no need of a physical router. If anyone can tell me the steps i need to take to make this happen. Thanks
Switch Model: Extreme Summit 400-48t
OS: EXTREMEWARE
(from William_Martinez)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Jul 15 2013 9:47AM
1.    Create the vlans (create vlan)
2.    Set ip addresses on them (configure vlan xxx ipaddress)
3.    Enable globlal ip-forwarding (enable ipforwarding)
4.    Enable ipforwarding for the specific vlans (enable ipforwarding xxx)
That should be enough i guess..
(from Henric)
