routing on extreme switch
  • Question
  • Updated 5 years ago
  • Answered
Create Date: Sep 20 2012 8:08AM
hi everybody...i have some problem.
i have a topology : checkpoint(eth2 : 10.1.12.17)---------(Port1 .vlan "CP : 10.1.12.18")ExtremeSwitch(port3 .vlan "server :10.1.10.1/24") ,on the switch extreme 480-24t I have 2 vlan :
 -vlan CP : 10.1.12.18/28 (add port 1,2) untaged ,
-vlan server 10.1.10.1/24.(add port 3, 4) untagged
ip have default route : config iproute add default 10.1.12.17
i enable ipforwarding.
from ExtremeSwitch, i ping server(10.1.10.3) ,ping gateway checkpoint (10.1.12.17) successfull.On server(10.1.10.3), i ping gateway vlan server (10.1.10.1). ping 10.1.12.18 vlan CP successfull, but i can not ping 10.1.12.17.....why ?
here this is my config file :
* X460-24t.1 # show config
# Module devmgr configuration.
configure sys-recovery-level switch reset
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1-30
configure vr VR-Default add ports 1-30
configure vlan default delete ports 1-10
create vlan "Connect_CP4200"
configure vlan Connect_CP4200 tag 2
create vlan "server"
configure ports 29 auto off speed 10000 duplex full
configure ports 30 auto off speed 10000 duplex full
configure vlan Connect_CP4200 add ports 1-2 untagged
configure vlan Default add ports 11-30 untagged
configure vlan server add ports 3-10 untagged
configure vlan Connect_CP4200 ipaddress 10.1.12.18 255.255.255.240
enable ipforwarding vlan Connect_CP4200
configure vlan server ipaddress 10.1.10.1 255.255.255.0
enable ipforwarding vlan server
# Module fdb configuration.
# Module rtmgr configuration.
configure iproute add default 10.1.12.17 2
# Module mcmgr configuration.
# Module aaa configuration.
configure account admin encrypted "FgvsOm$1s7QGJ1/rozr4cMoIpIMM0"
# Module acl configuration.
# Module bfd configuration.
# Module cfgmgr configuration.
# Module dosprotect configuration.
# Module dot1ag configuration.
# Module eaps configuration.
# Module edp configuration.
# Module elrp configuration.
# Module ems configuration.
# Module epm configuration.
# Module esrp configuration.
# Module ethoam configuration.
# Module etmon configuration.
# Module hal configuration.
# Module idMgr configuration.
# Module ipSecurity configuration.
# Module ipfix configuration.
# Module lldp configuration.
# Module msdp configuration.
# Module netLogin configuration.
# Module netTools configuration.
# Module poe configuration.
# Module rip configuration.
# Module ripng configuration.
# Module snmpMaster configuration.
disable snmp access
# Module stp configuration.
configure mstp region 0004966d4d49
configure stpd s0 delete vlan default ports all
disable stpd s0 auto-bind vlan default
enable stpd s0 auto-bind vlan Default
# Module telnetd configuration.
# Module tftpd configuration.
# Module thttpd configuration.
# Module vmt configuration.
# Module vsm configuration.
anybody help me.....
(from cuong_vu)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Sep 20 2012 7:30PM
HI, Check the routes on Chkpoint for your server VLAN.
Regards
PJ
(from PRASAD_JACOB)
Create Date: Sep 21 2012 12:49PM
Make sure the Checkpoint has the route for the server VLAN. You will either need to add it statically or use a routing protocol from the Extreme to the firewall. If there are only a few subnets I would do static routes.Let us know if this helpsP
(from Paul_Russo)
