RSPAN through LAG
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
Hi everybody.
I'm stuck with RSPAN configuration. I have three switches (image below). I'd like to configure RSPAN through.
enable sharing 25 grouping 25-26 algorithm address-based L2
Is it right configuration?
create mirror "RSPAN"
configure mirror RSPAN to port 25 remote-tag 99
configure mirror RSPAN add port 20 ingress-and-egress
Or I should do something like?
configure mirror RSPAN to port 25,26 loopback-port 24 remote-tag 99
Moreover, I got this message when I tried to use second configuration example.
Error: Port 25 cannot be added to VMAN as untagged because the port is a tagged VMAN member and a tagged VLAN member.
Mirror-to ports could not be added to mirroring VMAN!
Photo of eyeV
eyeV
  • 2,484 Points 2k badge 2x thumb
Posted 3 years ago
Photo of OscarK
OscarK, ESE
  • 7,912 Points 5k badge 2x thumb
Because port 25 and 26 are an MLAG they are logically 1 single port. I think you should be able to your first option.
Photo of eyeV
eyeV
Unfortunately no.
# enable mirror "RSPAN"
Error: Port mirroring cannot be enabled on a trunk member port 25
Photo of Alexandr P
Alexandr P, Embassador
  • 12,566 Points 10k badge 2x thumb
From User Guide 15.7
"A mirror port cannot be a LAG."
It's from limitations.
Thank you!
Photo of eyeV
eyeV
Thanks. I've read User Guide 15.4.
