RSTP between Extreme and Cisco
  • 2
  • Question
  • Updated 4 years ago
Hello,
Apologies for the the many posts. I'm relatively new to extreme.. Would just want to ask/seek help or sample configurations for anyone who has done RSTP config between Extreme and Cisco switches. Topology would be:
A----B
C----D
A&B are Extreme, C&D are Cisco. All are tagged/trunk ports.
thank you,
James
Photo of James Red
James Red
  • 322 Points 250 badge 2x thumb
Posted 4 years ago
  • 2
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
M6:U38
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1-50
configure vr VR-Default add ports 1-50
create vlan "data"
configure vlan data tag 20
create vlan "test"
configure vlan test tag 10
create vlan "unatagg"
configure vlan unatagg tag 50
configure ports 49 auto off speed 10000 duplex full
configure ports 50 auto off speed 10000 duplex full
configure vlan data add ports 1-2 tagged
configure vlan Default add ports 1-50 untagged
configure vlan test add ports 1-2 tagged
configure vr VR-Default delete protocol mpls
# Module stp configuration.
configure mstp region 0004968255cf
configure stpd s0 delete vlan default ports all
disable stpd s0 auto-bind vlan default
create stpd s1
create stpd s2
enable stpd s0 auto-bind vlan Default
configure stpd s0 add vlan Default ports 1 pvst-plus
configure stpd s1 add vlan test ports 1 emistp
configure stpd s2 add vlan data ports 1 emistp
configure stpd s0 add vlan Default ports 2 dot1d
configure stpd s1 add vlan test ports 2 pvst-plus
configure stpd s2 add vlan data ports 2 pvst-plus
configure stpd s0 tag 1
configure stpd s1 tag 10
enable stpd s1
configure stpd s2 tag 20
enable stpd s2
M7:U37
configure vr VR-Default delete ports 1-12
configure vr VR-Default add ports 1-12
create vlan "data"
create vlan "test"
configure vlan Default add ports 1-12 untagged
configure mstp region 000496839c40
create stpd s1
create stpd s2
configure stpd s2 priority 1
enable stpd s1
enable stpd s2
K7:U32(3550)
spanning-tree mode pvst
spanning-tree extend system-id
vlan 10,20-21
vlan 50
name UNTAGGED
vlan 200
interface FastEthernet0/1
switchport trunk encapsulation dot1q
switchport mode trunk
interface FastEthernet0/2
K7:U33:
interface GigabitEthernet3/0/2
no shutdown
interface GigabitEthernet3/0/3
no shutdown
vlan 10,20-21
Point to be consider:
1)      In Cisco, the Uplink to Extreme will be a trunk port. ( if not, ask him to do it) So, we need to add all the VLANs as tagged VLANs in the uplink port to Cisco.
2)      In Cisco, there is no need to configure the tag value for VLAN/STP domain (every instance running in Cisco for per VLAN – can be called as different STP domain). Because they create VLAN with numbers which is the tag value.
So, we need to tag the STPD domain in our switch. We will be creating 1 STPD for 1 VLAN. So, for that STPD, the tag value should be exactly same as the VLAN which is participating in that STPD domain.
3)      VLAN left is the “the native VLAN” in Cisco. By default, VLAN 1 is the native VLAN in Cisco. Check if customer is using the VLAN 1 for data purpose. If customer is not using, then just delete our VLAN “default” from the uplink port. If he is using, simply add our “Default” VLAN to any of the created STPD domain. Trust me, it will work. But, make sure you are adding the VLAN “default” to the same STPD domain in all the other switches.
Photo of James Red
James Red
Thank you for the info Summit. Some clarifications:
  • if I have 4 VLANS passing through that link, do I have to create 4 stpd instances?
  • Why is it that ports 1&2 uses different types, emistp and pvst-plus?
  • If I will not use Default VLAN, can I just delete it from s0 and disable s0?
(Edited)
Sumit Tokle, Alum
Yes, 4 STPD domain.
You can configure it as PVST-plus. This doesn't make any major difference.
Photo of James Red
James Red
ok, noted on that.
I more question, I noticed that in M6 you didn't configure priority for s1 and s2. In M7 you configured priority in s2 only giving it a value of 1(higher priority).
  • Does that mean that each vlan/stpd has its own priority?
  • Is it possible that in a same switch(m7), port2 for s2 is forwarding while the port2 for s1 is blocking since it has lower priority?
Photo of James Red
James Red
One more thing, what if Cisco uses RSTP instead of PVST, how should the configuration on extreme side be?
Sumit Tokle, Alum
Yes. every STPD domain has it's own priority.
You can play with priority or port cost to change the forwarding/blocking.
RSTP: Hint: Think about, how cisco works with RSTP. If there are 10 vlans configured with RSTP on Cisco then how many BPDU packet Cisco device will sent out? What is the TAG value those BPDU?
Depending upon that configure it on Extreme devices.
Please go through EXOS concept guide for further information.
Photo of James Red
James Red
Hi Sumit,
Can you give me a little more hint on the rstp config? :) Will the basic config below work when interconnecting with Cisco?
3 VLANS will pass through the link, all ports tagged
VLAN100 - Test1, ports 1:1, 1:2 tagged
VLAN101 - Test2, ports 1:1, 1:2 tagged
VLAN102 - Test3, ports 1:1, 1:2 tagged
create stpd Test
configure stpd Test mode dot1w
configure stpd Test add vlan Test1 ports 1:1,1:2
configure stpd Test add vlan Test2 ports 1:1,1:2
configure stpd Test add vlan Test3 ports 1:1,1:2
configure stpd Test ports link-type point-to-point 1:1,1:2
configure stpd Test tag 100
Thanks!
Sumit Tokle, Alum
The above configuration may work.
The configuration is always depends on other end(Cisco) also.
Photo of Jhonn Bejar
Jhonn Bejar
  • 320 Points 250 badge 2x thumb
I'm four months watching extreme switches, everything was fine until I got to configure spanning tree.
on cisco virtually nothing to configure spanning tree with almost everything is automated.
but extreme it is very confusing.
If I enable pvst + must create a domain per vlan, associating ports, just watch the "show configuration stp" is long.
with that my clients are scared. They are accustomed to something practical and simple to configure.
I think that should change how extreme configure spanning tree
