Running EXOS on VMware
  • Problem
  • Updated 2 weeks ago
I went here https://github.com/extremenetworks/Virtual_EXOS and downloaded the ISO
I booted from the ISO and it tells me it can't find install.xos
The doc referenced on Github (https://github.com/extremenetworks/Virtual_EXOS/blob/master/Install_Guide_EXOS-VM-ESXi-5.docx?raw=tr...) says nothing about that.
In fact it fails at "Starting External Memory Card device" with "mounting /dev/hdc on /mnt/a failed: No such device or address"
Photo of jeronimo
jeronimo
  • 1,384 Points 1k badge 2x thumb
Posted 2 weeks ago
Photo of Tyler Marcotte
Tyler Marcotte, Official Rep
  • 2,784 Points 2k badge 2x thumb
Hi jeronimo,
Check to make sure your Hard disk is set for IDE 0:0. I think that caused me an issue in the past.
Thanks,
Tyler
Photo of jeronimo
jeronimo
Ha! The problem is similar: the ISO needs to be shown as IDE 1:0 whereas the default would be 0:1. Tricky stuff. The Word document actually shows it in the screenshot but there is no warning in its text ;-)
Photo of jeronimo
jeronimo
This makes sense since the error contained "/dev/hdc ...", meaning the boot loader tries to mount itself. Which also makes sense. In the beginning I thought I needed a separate ".xos" files which is not true.
Photo of Drew C.
Drew C., Community Manager
  • 40,218 Points 20k badge 2x thumb
You can use the .xos file to upgrade an existing EXOS VM in the future so you don't have to contend with VMware next time.
Ahh yes, I forgot about that part since I removed the CD ROM drive after the install. Glad you got it working!
