Running script report an error Could not load report.
  • Problem
  • Updated 1 year ago
  • Not a Problem
When I try to run a script in IE or Firefox the error  'Could not load report' is displayed.
Message: A Sorter requires either a property or a sorterFn.
Ext.util.Sorter.constructor(): A Sorter requires either a property or a sorterFn. at raise (https://<IP-ADDER>:8443/OneView... Suite 7.1.1.9:1975:17) at constructor (https://<IP-ADDER>:8443/OneView... Suite 7.1.1.9:24035:17) at constructor (https://<IP-ADDER>:8443/OneView... Suite 7.1.1.9:7657:13) at Function code (Function code:1:1) at create (https://<IP-ADDER>:8443/OneView... Suite 7.1.1.9:8894:13) at decodeSorter (https://<IP-ADDER>:8443/OneView... Suite 7.1.1.9:52299:13) at decodeItems (https://<IP-ADDER>:8443/OneView... Suite 7.1.1.9:43277:21) at splice (https://<IP-ADDER>:8443/OneView... Suite 7.1.1.9:42624:13) at addSort (https://<IP-ADDER>:8443/OneView... Suite 7.1.1.9:52206:13) at sort (https://<IP-ADDER>:8443/OneView... Suite 7.1.1.9:46708:13)
In Chrome I don't have this issue
Photo of Johan Hendrikx
Johan Hendrikx
  • 3,804 Points 3k badge 2x thumb
Posted 2 years ago
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 6,058 Points 5k badge 2x thumb
Hi Johan,
I could see an article with similar issue not sure how it works with Chrome but still can you give it a try and check?
https://gtacknowledge.extremenetworks...
Johan Hendrikx
I have NMS and don't see report designer when  I select the administration tab
(Edited)
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,114 Points 50k badge 2x thumb
What license is installed i.e. NMS, NMS-Base, NMS-ADV
Johan Hendrikx
License is NMS
