Rx CRC and Rx Jabber
Ian_Broadway
New Contributor III
Hello,
We're experiencing infrequent CRC/Jabber errors on a particular interface between 2 670v-48x switches. Switches are running code version 15.3.1.4 patch 1-18 at the moment. They run our iSCSI network.
Both ports connected together, 49-49 on each switch experience the errors, connected via pre terminated copper cable, Q+CR4_3m.
I have checked that the cable is not in the vicinity of electrical cables to try to rule out interference.
Would it simply be a bad cable/module on the cable that causes this? We've had to change this before so I'm concerned it may be the slot(s) in the switch(es) itself?
Any thoughts welcome 🙂
Ian
4 REPLIES 4
Sushruth_Sathya
Rx Jabber can increment under the following situations -
* packet data length exceeds configured MTU (1518 for non-jumbo and 9018 for jumbo) and/or
* has a bad CRC.
Most likely, it will be a Layer 1 related problem and as a first step as Karthik suggested, it would be best to replace the cable.
Bnoba_CEO
I have a similar issue. Can someone give a hint on resolution.
Drew_C
Valued Contributor III
Hello Ian, are you still having trouble with CRC errors?
Karthik_Mohando
Hi Ian, I would suggest the first and easy step is to swap the DAC cable and see if the RX-errors are changes to the other end.
