S-Series DHCP problem and ip route add default, version 7.22.02.001
  • Question
  • Updated 3 years ago
  • (Edited)
Greetings.
I have a chassis S6 that should give for 70 DHCP address pools with mask (/ 25 and / 24). Each pool has a corresponding VLAN (30,31,32 ...). For example:
VLAN 1 - 10.17.3.231/24 (ip address for switch.)
VLAN 30 - ip 10.17.30.1/25 ip v30 pool 10.17.30.0/25
VLAN 31 - ip 10.17.30.129/25 ip v31 pool 10.17.30.128/25
ip address for Internet firewall 10.17.3.254/24
Having created a number of DHCP pools, sends me an error and I can no longer create more pools. Also, what would be the best way to make a "ip route" that VLANs allows the ip firewall Internet (10.17.3.254/24)? enable ip forwarding it ́s ok.
Note: The firmware version I have is 07.22.02.001
What can I do in this situation?, thank you very much.
Photo of Luis Bernal
Luis Bernal
  • 120 Points 100 badge 2x thumb
Posted 3 years ago
Be the first to post a reply!
