S-series S4 transceiver led indicators
Robert_Zdzieblo
Contributor II
I have noticed on S4 chassis equipped with I/O fabrics modules that transceiver leds are blinking with 2 different colours: most of them are green, but some are amber (see enclosed images - I hope it is visible).
94427c841c284d85b2b9fd6ba5bbdc13_RackMultipart20180516-14071-1l7kujd-IMG_20180516_121405_inline.jpg
Anyone knows what that colours mean ?
REGARDS
Robert
4 REPLIES 4
Robert_Zdzieblo
Contributor II
OK, that makes sense now, as S4 is receiving video streaming traffic from cameras connected to edge switches.
Thanks again, Mel78 !
Mel78__CISSP__E
New Contributor III
f7d4e0ffe98645a49b6a80bda5059175_RackMultipart20180518-18314-1wxvusx-2018-05-18_184229_inline.png
Apologies, the Entrasys S-series SFP+ is different. Refer above.
Robert_Zdzieblo
Contributor II
Thank you Mel78,
That it interesting, casue all my links are 10Gb and their speed is actually 10Gb, when checking port status on S4.
Is that possible at all to have 100Mb speed on SFP+ fiber transceivers ?
REGARDS
Robert
Mel78__CISSP__E
New Contributor III
Generally, all ethernet port status dual LED status as follow.
left LED blinking means theres activity.
left led: Amber means 100Mbps. left led: Green means its 1 Gbps or more.
Right led: Green means port status is active.
If right led green is also blinking, means its very odd.
