S1- Hardware Utilization (IDLE)
  • Problem
  • Updated 4 years ago
  • Solved
Hi friends,
I have a problem, I have a s1 with approximately 1200 users, sometimes the computer processing up to 95%. In the show I can see that support the process up is one called "IDLE" I wonder which may be ocacionados this problem.
Photo of Rafael Andres Martinez Jimenez
Posted 4 years ago
Photo of Michael Langley
Michael Langley, Employee
  • 620 Points 500 badge 2x thumb
Official Response
Hello Rafael Andres Martinez Jimene,
The 'idle' process is the percentage of time the CPU is not working, active, or being used.
It is normal for this task to have the highest percentage of time associated with it.
It is similar to the 'System Idle Process' on the Microsoft Windows Operating System.
If you run the command 'show system utilization cpu' it will show the total process utilization not including the 'idle' process.
If there are times when the 'show system utilization cpu' results show 95% you would then want to run the 'show system utilization process' command and see which non-idle process or processes are running high.
Thank you.
