S4 series chassis SLOT 2 COM LED not glowing
  • Problem
  • Updated 2 years ago
  • Solved
We have S4 Series Chassis loaded with
S4 Chassis I/O Fabric Module: 48 ports 1000BASE-X  at Slot 2..
When we try to communicate with chassis through hyper terminal, there is no response.
We notified that LED on the chasis for slot 2 is not blinging..
Status of CPU & MGMT are glowing for slot2..
What is the LED status available on the top of the chassis
Photo of Jeyaprkash V
Jeyaprkash V
  • 152 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 47,244 Points 20k badge 2x thumb
Jeyaprkash V
Thanks for your quick reply.
We understand from the link provided is that  “ The green-lit status LED under a chassis-based USB port indicates the presence of an operational mapped slot module,”
In our case we have installed fabric module at slot 2 and its CPU and MGMT LED are glowing.
It means that it is operational but LED at the top of chassis for slot 2 is not glowing. Do we need to do any configuration / settings on the chassis.
I have attached the photo of the chassis for quick reference
(Edited)
Photo of Mike D
Mike D, Alum
  • 3,852 Points 3k badge 2x thumb
Hello,
This LED is acting up - no configuration is normally necessary to make it go.
May be something as simple as a loose light pipe - but I'd expect this led to be lit in your picture.
A call to support is probably in order.
Regards,
Mike
Jeyaprkash V
Hello,
The problem is not only LED is liting up..  It is not responding (hyper terminal scereen) when we tried connected it through COM port
