S8 legacy installed based configuration doubt
Fernando_Sergio
Could you please help me identify this customer chassis configuration and why it shows slots numbers higher than 8 if the chassis has only 8 slots?
Chassis Serial Number: 122252xxxxxx
Slot Model Serial # Versions
2 ST4106-0248 121102xxxxxx
5 SK1208-0808-F6 141904xxxxxx
6 SK1208-0808-F6 122354xxxxxx
8 ST4106-0248 100854xxxxxx
10 ST4106-0248 121101xxxxxx
13 SK1208-0808-F6 122252xxxxxx
14 SK1208-0808-F6 122353xxxxxx
16 ST4106-0248 121102xxxxxx
Option Modules:Slot Module Model Serial # Versions
5 1 SOK1208-0104 122200xxxxxx Hw: 8
5 2 SOG1201-0112 114403xxxxxx Hw: 8
13 1 SOK1208-0104 122200xxxxxx Hw: 8
13 2 SOG1201-0112 121153xxxxxx Hw: 8
(Edited by CM to mask serials)
4 REPLIES 4
Fernando_Sergio
Hia all, I imagine the chassis is in bounding but I could not find a fabrica module that supports the VSB feature, since customer is using SK1208-0808-F6
If the fabric doesn't have dedicated VSB ports, then it must have the license S-EOS-VSB: S-Series Multi-slot chassis Virtual Switch Bonding License Upgrade, (For use on S130/S150 Class Modules and S140/S180 Class Modules without HW VSB ports)
Ronald_Dvorak
Honored Contributor
Looks like that the customer has 2x S8 chassis bonded together.
You'd run the below command to see all the information....
XYZ(su)->show system hardware brief
CHASSIS 1 HARDWARE INFORMATION
Chassis Type: Bonded S8 Chassis (0x13)
Daniel_Coughlin
This system is running Chassis Bonding and is comprised of two S8 chasssis with connected with ports converted to bonding ports. This article gives a sample: How to configure Virtual Switch Bonding (VSB) on S-Series or K-Series
