S-Series CPU Utilization Spike on the "Hardware Maintenance" task
  • Article
  • Updated 5 years ago
Article ID: 12846
Products
S-Series
Symptoms
The output of a 'show system utilization' command displays high CPU utilization on the "Hardware Maintenance" task.
Possible module reset.
In the output of a 'show support' command, the message log contains one or more items similar to this:
<3>bcmStrat[2.bcmDPC]unit 0 L3_ENTRY_ONLY entry 2139 parity error
Solution/Workaround
Please contact the GTAC for assistance.
Workaround:
A module reset, which occurs automatically with firmware 7.03.xx.xxxx and higher, will temporarily clear the high CPU utilization. With lower firmware, the user may manually issue a reset for this purpose.
Photo of FAQ User
FAQ User, Official Rep
  • 13,610 Points 10k badge 2x thumb
Posted 5 years ago
There are no replies.
