S-Series f/w 7.03.03.0001 displays alternating Environmental Temperature Hot / Normal messages
  • Article
  • Updated 5 years ago
Article ID: 13226
Products
S-Series, firmware 7.01.03.0004 through 7.03.06.0004
Symptoms
The system logs "hot" messages, then "normal" messages a short time later.
Here is the syslog output ('show logging buffer') - in ascending sequence - from an affected system:
<163>Jun 15 10:41:14 10.21.31.2 System[3]Environmental temperature is hot.
<163>Jun 15 10:41:24 10.21.31.2 System[3]Environmental temperature is normal.
<163>Jun 19 07:51:18 10.21.31.2 System[3]Environmental temperature is hot.
<163>Jun 19 07:51:28 10.21.31.2 System[3]Environmental temperature is normal.
<163>Jun 22 17:41:20 10.21.31.2 System[3]Environmental temperature is hot.
<163>Jun 22 17:41:30 10.21.31.2 System[3]Environmental temperature is normal.
<163>Jun 25 00:22:40 10.21.31.2 System[3]Environmental temperature is hot.
<163>Jun 25 00:22:50 10.21.31.2 System[3]Environmental temperature is normal.
<163>Jun 25 08:51:13 10.21.31.2 System[3]Environmental temperature is hot.
<163>Jun 25 08:51:23 10.21.31.2 System[3]Environmental temperature is normal.
<163>Jun 28 20:40:14 10.21.31.2 System[3]Environmental temperature is hot.
<163>Jun 28 20:40:24 10.21.31.2 System[3]Environmental temperature is normal.
<163>Jun 29 13:32:37 10.21.31.2 System[3]Environmental temperature is hot.
<163>Jun 29 13:32:47 10.21.31.2 System[3]Environmental temperature is normal.
Here is the fault log output ('show support') - in descending sequence - from the same system:
Message 1/43 Syslog Message 07.03.03.0001 06/29/2010 13:32:47
<3>System[3]Environmental temperature is normal.
Message 2/43 Syslog Message 07.03.03.0001 06/29/2010 13:32:37
<3>System[3]Environmental temperature is hot.
Message 3/43 Syslog Message 07.03.03.0001 06/28/2010 20:40:24
Message 4/43 Syslog Message 07.03.03.0001 06/28/2010 20:40:14
Message 5/43 Syslog Message 07.03.03.0001 06/25/2010 08:51:23
Message 6/43 Syslog Message 07.03.03.0001 06/25/2010 08:51:13
Message 7/43 Syslog Message 07.03.03.0001 06/25/2010 00:22:50
Message 8/43 Syslog Message 07.03.03.0001 06/25/2010 00:22:40
Message 9/43 Syslog Message 07.03.03.0001 06/22/2010 17:41:30
Message 10/43 Syslog Message 07.03.03.0001 06/22/2010 17:41:20
Message 11/43 Syslog Message 07.03.03.0001 06/19/2010 07:51:28
Message 12/43 Syslog Message 07.03.03.0001 06/19/2010 07:51:18
Message 13/43 Syslog Message 07.03.03.0001 06/15/2010 10:41:24
Message 14/43 Syslog Message 07.03.03.0001 06/15/2010 10:41:14
Cause
These are false positive readings, when no actual over-temp condition exists.
Solution/Workaround
Upgrade to firmware 7.11.01.0026 or higher.
Release notes state, in the 'Firmware Changes and Enhancements' section:
Management
Incorrect data read from the temperature sensor device may produce intermittent warning messages regarding environmental temperatures. Inaccurate warning messages similar to "<3>System[3]Environmental temperature is hot." may occur followed 10 seconds later by a messages similar to "<3>System[3]Environmental temperature is normal."
Pre-upgrade workaround:
Such rapidly-correcting "hot" messages may be safely ignored.
Messages that do not appear to be self-correcting should be investigated further, by using the 'show system hardware' command to view the underlying board temperature readings (13189).
Contact the GTAC for assistance, as necessary.
Photo of FAQ User
FAQ User, Official Rep
  • 13,620 Points 10k badge 2x thumb
Posted 5 years ago
There are no replies.
