Sample OSPF Configuration on N-Series
  • Article
  • Updated 4 years ago
Article ID: 5058
Matrix N-Series
Sample configuration
The following sample shows a fully formed adjacency between two ospf routers (DFE and X-Pedition) using a modified OSPF priority and cost value.
The sample assumes the user has knowledge related to configuration of ospf fundamentals as well as vlan configuration.
It is mandatory that the user purchase and apply an Advanced Routing license to enable this configuration feature. The "network" and "redistribute" commands will otherwise not be available (see 5025).
The shared link between routers is on vlan 10. Following the DFE configuration is the XP configuration to which the DFE was connected.
# Router instance 3 Configuration
begin router 3
set router 3
router 3
config t
license advanced <license-key>
router id
interface vlan 1
ip address
no shutdown
interface vlan 10
ip address
no ip proxy-arp
no shutdown
ip ospf cost 20
ip ospf priority 20
interface vlan 20
ip address
no shutdown
router ospf 555
network area
redistribute connected metric 300
write file
end router 3
XP8# system show active-config
Running system configuration:
! Last modified from Console on 2003-05-06 09:25:35
1 : interface create ip bb1 address-netmask port et.6.1
2 : interface create ip a1 address-netmask port et.6.2
3 : ospf create area backbone
4 : ospf add interface bb1 to-area backbone
5 : ospf add interface a1 to-area backbone
6 : ospf start
7: system set name XP8
Photo of FAQ User
FAQ User, Official Rep
  • 13,590 Points 10k badge 2x thumb
Posted 4 years ago
There are no replies.
