Scrolls "soc_schan_op: operation timed out" Errors and does not Fully Boot
  • Problem
  • Updated 2 years ago
  • Solved
After firmware update, I cannot boot the unit successfully anymore!
I'm trying to reactivate two A2H124-24 units, which had been already dismantled, but shall be used for a charity project here now.
Setting from the previous owners did not let us simply use it, so we thought we should take this opportunity to also bring the software to its actual release.
IIt took me some time to find a workable way to upload the firmware with OS X, terminal app and an xmodem utility "lsx" I found here:  http://www.ohse.de/uwe/software/lrzsz.html
Many attempts with other temrinal apps, didn't work. Altough uploading seemed to do well, it was then said that the image was not compatible with the hardware.
anyway, with the a.m. apps, it worked, I uploaded the image and loaded the new code.
vital info says this:
The following Enterasys Header is in the image:
MD5 Checksum....................bf30f0d332895b0f7788ac1ef48ca6d5
Boot File Identifier............0x0517
Header Version..................0x0100
Image Type......................0x82
Image Offset....................0x00c3
Image length....................0x005d1b3d
Ident Strings Length............0x0098
Ident Strings...................A2H124-24
                                A2H123-24
                                A2H124-24P
                                A2H124-48
                                A2H124-48P
                                A2H124-24FX
                                A2H254-16
                                A4H124-24TX
                                A4H124-24FX
                                A4H254-8F8T
                                A4H124-24
                                A4H124-24P
                                A4H124-48
                                A4H124-48P
Image Version Length............0xd
Image Version Bytes.............0x30 0x33 0x2e 0x30 0x33 0x2e 0x30 0x36 0x2e 0x30 0x30 0x30 0x31 (03.03.06.0001)
The following secondary header is in the image:
CRC............................................0x5611 (22033)
Target Device..................................0x00a08245
Size...........................................0x5d1b38 (6101816)
Number of Components...........................2
Operational Code Size..........................0x555a18 (5593624)
Operational Code Offset........................0x0 (0)
Operational Code CRC...........................0xA63D
Boot Code Version..............................51
Boot Code Size.................................0x7bed0 (507600)
Boot Code Offset...............................0x555a18 (5593624)
Boot Code CRC..................................0x26AD
VPD - release major 3 minor 3 maint 6 build 1 alpha -
      Timestamp - Thu Nov 13 23:46:24 2014
      File - a-series_03.03.06.0001
So, I assume, installation did do fine. I also updated the boot loader.
Now, what happens after loading the operatinal code is that there's a continous scrolling with errors starting with: soc_schan_op: operation timed out, similar to the description I did find here: https://gtacknowledge.extremenetworks.com/articles/Solution/SecureStack-Scrolls-soc-schan-op-operati...
I would be glad if you guys could help me out of this trap!!!
Photo of sailor
sailor
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of sailor
sailor
bounce
Photo of George, Chris
George, Chris, Employee
  • 922 Points 500 badge 2x thumb
The error message you provided indicates you have a failed piece of hardware.  There is no way to recover the unit.
