Searching for Extreme MIBs (not base-mib)
  • Question
  • Updated 3 years ago
  • Answered
Hello,
Is there a location on your website where I could get various Extreme MIBs (like EXTREME-NP-MIB, EXTREME-ESRP-MIB, EXTREME-VLAN-MIB, EXTREME-QOS-MIB, EXTREME-EAPS-MIB, EXTREME-EDP-MIB, EXTREME-VLAN-MIB, EXTREME-LACP-MIB) and others that the manual refers to?
All I see is the BASE-mib, aka "<version>_MIB.txt" when I go to the download section where I can get to the XOS images. When I include that in my snmp configs, I get a lot of "can't find" warnings/errors
Of course I can google the missing ones and grab a copy from the various OID repositories on the web, but I'd rather get them straight from you ;)
Thanks,
     Frank
Photo of Frank
Frank
  • 3,836 Points 3k badge 2x thumb
Posted 3 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,606 Points 10k badge 2x thumb
Official Response
Hi Frank,
These MIBs should be included in the"<version>_MIB.txt" file that you see with the software downloads. If you open it in a text editor, you should be able to search for the specific MIB that you are looking for to confirm it is in the file.
If there is a specific OID that seems to be causing these issues, or if one of these MIBs is missing from the file, let me know and I can take a look.
-Brandon
Photo of Frank
Frank
Official Response
Ah, got it! Net-SNMP seems a little iffy with mib files that contain multiple definitions, it seems.
"smistrip <version>_MIB.txt" in your mibs-directory, and an entry of "mibs +EXTREME-BASE-MIB" in /etc/snmp/snmp.conf did wonders.
"smistrip", which is part of the "libsmi" package in CentOS, creates individual mib-files, one per "DEFINITIONS", from text files.
Now I just have to remember what I did before I descended into this rabbit hole... ;)
