SecureStack B5 resets every 2 weeks
Michael_Rosolsk
New Contributor II
The switch restarts every 2 weeks for no apparent reason. Unfortunately, I can not find any abnormalities in the logs. Do you have an idea?<167>Feb 10 09:31:36 10.254.0.36 UNKN[190618160]: usmdb_keying.c(1686) 218107 This is from manager 1 % License DB task: update from unit 2 time SAT FEB 10 08:31:35 2018
<167>Feb 10 09:31:50 10.254.0.36 UNKN[190618160]: usmdb_keying.c(1686) 218109 This is from manager 1 % License DB task: update from unit 3 time SAT FEB 10 08:31:49 2018
<167>Feb 10 09:31:58 10.254.0.36 UNKN[190618160]: usmdb_keying.c(1686) 218111 This is from manager 1 % License DB task: update from unit 4 time SAT FEB 10 08:31:57 2018
<167>Feb 10 09:32:10 10.254.0.36 UNKN[190618160]: usmdb_keying.c(1686) 218113 This is from manager 1 % License DB task: update from unit 1 time SAT FEB 10 08:32:09 2018
<167>Feb 10 09:32:15 10.254.0.36 UNKN[190618160]: usmdb_keying.c(1686) 218114 This is from manager 1 % License DB task: update from unit 5 time SAT FEB 10 08:32:14 2018
<167>Feb 10 09:32:36 10.254.0.36 UNKN[190618160]: usmdb_keying.c(1686) 218118 This is from manager 1 % License DB task: update from unit 2 time SAT FEB 10 08:32:35 2018
<167>Feb 10 09:32:36 10.254.0.36 UNKN[190618160]: usmdb_keying.c(2472) 218119 This is from manager 1 % License DB check
<167>Feb 10 09:32:50 10.254.0.36 UNKN[190618160]: usmdb_keying.c(1686) 218121 This is from manager 1 % License DB task: update from unit 3 time SAT FEB 10 08:32:49 2018
<167>Feb 10 09:32:58 10.254.0.36 UNKN[190618160]: usmdb_keying.c(1686) 218122 This is from manager 1 % License DB task: update from unit 4 time SAT FEB 10 08:32:57 2018
Enterasys B5-Series Boot Code...
SDRAM Circuit Test of 512MB
1% ... 100%
Version 02.02.15 04-25-2012
Computing MD5 Checksum of operational code...
Select an option. If no selection in 2 seconds then
operational code will start.
1 - Start operational code.
2 - Start Boot Menu.
Select (1, 2):
Operational Code Date: Wed May 24 14:35:45 2017
Uncompressing.....
50% 100%
Adding 77303 symbols for standalone.
WatchdogTask - Active
Inst Memory Protection - Active
Instantiating /ramDrv:0 as rawFs, device = 0x30001
Instantiating /snpDrv:0 as rawFs, device = 0x40001
SOC unit 0 attached to PCI device BCM56514_A0
SOC unit 1 attached to PCI device BCM56514_A0
Adding BCM transport pointers
Configuring CPUTRANS TX
Configuring CPUTRANS RX
st_state(0) = 0x0
st_state(1) = 0x2
MonitorTask - Active
(Unit 1)(STACK: master on 20:b3:99:b5:56:d8 (5 cpus, 10 units)
STACK: attach 2 units on 1 cpu
This switch is manager of the stack.
Trying to attach more units.....
regards
Michael
4 REPLIES 4
Michael_Rosolsk
New Contributor II
power cycle the stack solves this isssue.
Steve_Geisser
Hello Michael,
We would need to review the full "show support" and "current.log" to investigate what is causing the resets. I would recommend opening a case with GTAC.
Best Regards,
Steve Geisser
GTAC ESE
Hello Steve,
i have opened a case (01501077).
regards
Michael
Reference: https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-contact-Extreme-Networks-Global-Tec...
Doug Hyde
Director, Technical Support / Extreme Networks
