SecureStack: Question regarding ACL vs. Policies
  • Question
  • Updated 1 year ago
  • Answered
Is it possible to use ACL (on a VLAN) AND (Enterasys) policies (on ports) (different VLANs and different ports) at the same time ? (with current 6.81.08)
I older 6.42. / 6.61. is was not possible to use that on the same system ...
Unfortunately there are no logging or counting option for ACL or Policies on SecureStack - is there another way to debug / troubleshoot ti see if ACL or Access Rules are used ?
(except do a wireshark on mirror port or capture trace and run it into POlicy Manager ...)
Photo of M.Nees
M.Nees, Embassador
  • 9,168 Points 5k badge 2x thumb
Posted 1 year ago
Photo of French, Luke
French, Luke, Employee
  • 712 Points 500 badge 2x thumb
Below  is from the 6.81 release notes
 ACLs
Access Control Lists (ACLs) use the same hardware resources as Policy rules and cannot be used simultaneously with Policy.
 I know of no way to debug the ACL.
Photo of M.Nees
M.Nees, Embassador
This kind of limition and dependencies make sometimes features unuseable ... and my job not really attractive ...
Several times i need in VLAN-A ACLs and VLAN-B/C/D policies with NAC ....
Switching over to ACL completely is also not possible because ACLs are not send to Switch via RADIUS Attributes ....
Let' s switch over to EXOS ...
BTW: Is in EXOS a simultaneously usage of ACLs (=Extreme Policy) and OnePolicy Framework possibel ???
Regards
Photo of M.Nees
M.Nees, Embassador
To repeat and address my question to EXOS guys:
You can run ACL and policy simultaneously on EXOS.
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,838 Points 5k badge 2x thumb
Yes, you can run them both, but OnePolicy ACL's are dynamic ACL's and are higher precedence than a .pol ACL.  So if you have the same match condition but different actions the OnePolicy ACL's action will be used.
