SecureStack C2 License Messages in Logging Buffer and Syslog
  • Article
  • Updated 5 years ago
Article ID: 5895
Products
SecureStack C2
C2L3-LIC
Symptoms
License messages in logging buffer and syslog
'set license'
'set logging'
'show logging buffer'
"UNKN[]: usmdb_keying.c() %% License Re-evaluate."
"UNKN[]: usmdb_keying.c() %% License DB task: update from unit time"
"UNKN[]: usmdb_keying.c() %% License DB check"
Cause
When a C2L3-LIC Advanced Router license has been configured (5828), "License" messages will appear in the output of a 'show logging buffer' command if both the "System" application and default severity have been set to "debug" level 8 ('set logging application System level 8', 'set logging default severity 8').
This is demonstrated below.
 C2(rw)->router
C2(rw)->router>enable
C2(rw)->router#config
Enter configuration commands:
C2(rw)->router(Config)#license advanced abcdefg123456789
C2(rw)->router(Config)#exit
C2(rw)->router#show license
C2(rw)->router#exit
C2(rw)->router>exit
C2(rw)->show logging buffer
C2(rw)->set logging application System level 8
C2(rw)->set logging default severity 8
<167> MAY 16 16:03:27 172.26.6.3-1 UNKN[184472624]: usmdb_keying.c(1359) 884 %%
License DB task: update from unit 1 time WED MAY 16 16:03:27 2007
<167> MAY 16 16:04:27 172.26.6.3-1 UNKN[184472624]: usmdb_keying.c(1359) 885 %%
License DB task: update from unit 1 time WED MAY 16 16:04:27 2007
<167> MAY 16 16:04:27 172.26.6.3-1 UNKN[184472624]: usmdb_keying.c(2138) 886 %%
License DB check
<167> MAY 16 16:05:27 172.26.6.3-1 UNKN[184406360]: usmdb_keying.c(3107) 887 %%
<167> MAY 16 16:05:27 172.26.6.3-1 UNKN[184472624]: usmdb_keying.c(1359) 888 %%
License DB task: update from unit 1 time WED MAY 16 16:05:27 2007
<167> MAY 16 16:06:27 172.26.6.3-1 UNKN[184472624]: usmdb_keying.c(1359) 889 %%
License DB task: update from unit 1 time WED MAY 16 16:06:27 2007
<167> MAY 16 16:07:27 172.26.6.3-1 UNKN[184472624]: usmdb_keying.c(1359) 890 %%
License DB task: update from unit 1 time WED MAY 16 16:07:27 2007
<167> MAY 16 16:07:27 172.26.6.3-1 UNKN[184472624]: usmdb_keying.c(2138) 891 %%
License DB check
<167> MAY 16 16:08:27 172.26.6.3-1 UNKN[184472624]: usmdb_keying.c(1359) 892 %%
License DB task: update from unit 1 time WED MAY 16 16:08:27 2007
<167> MAY 16 16:09:27 172.26.6.3-1 UNKN[184472624]: usmdb_keying.c(1359) 895 %%
License DB task: update from unit 1 time WED MAY 16 16:09:27 2007
<167> MAY 16 16:10:27 172.26.6.3-1 UNKN[184406360]: usmdb_keying.c(3107) 897 %%
<167> MAY 16 16:10:27 172.26.6.3-1 UNKN[184472624]: usmdb_keying.c(1359) 898 %%
License DB task: update from unit 1 time WED MAY 16 16:10:27 2007
<167> MAY 16 16:10:27 172.26.6.3-1 UNKN[184472624]: usmdb_keying.c(2138) 899 %%
License DB check
<167>MAY 16 16:11:27 172.26.6.3-1 UNKN[184472624]: usmdb_keying.c(1359) 900 %%
License DB task: update from unit 1 time WED MAY 16 16:11:27 2007
<167>MAY 16 16:12:27 172.26.6.3-1 UNKN[184472624]: usmdb_keying.c(1359) 901 %%
License DB task: update from unit 1 time WED MAY 16 16:12:27 2007
C2(rw)->clear logging application System
C2(rw)->clear logging default severity
C2(rw)->
The frequency of each message is...
  • every 5 minutes, "License Re-evaluate.";
  • every 1 minute, "License DB task: update from unit...";
  • every 3 minutes, "License DB check".
Further, if a syslog server has been configured to receive any generated "debug" level 8 messaging ('set logging server 1 ip-addr <IP_address> severity 8 state enable'), it will also receive these "License" messages.
Solution
FAD (Functions as Designed).
If you do not want to see these messages, set either the "System" application or default severity no higher than "informational" level 7.
Photo of FAQ User
FAQ User, Official Rep
  • 13,610 Points 10k badge 2x thumb
Posted 5 years ago
There are no replies.
