SecureStack C2 Unit changed position in a Stack
  • Article
  • Updated 4 years ago
  • (Edited)
Article ID: 7247
Matrix C2
SecureStack C2
Stack unit changed position in stack.
SecureStack switch lost stack unit number.
Securestack switch lost port configurations.
'show switch'
Upgrade to firmware 3.01.94 or higher.
Release notes state, in the 'Firmware Changes and Enhancements" section:
In previous versions a condition could occur in which a unit could leave and rejoin the stack, this has been corrected.
Otherwise, contact Enterasys Networks Technical Services for assistance.
To change the incorrect unit# (x_switch#) back to the original unit# (y_switch#) if the original unit# is still available - typically the case in these situations:
  set switch <x_switch#> renumber <y_switch#>
To swap two unit numbers (x_switch# and y_switch#) if both unit#s currently have a physical switch present and assigned to it, requires the use of an unused unit# (z_switch#):
  set switch <x_switch#> renumber <z_switch#>
set switch <y_switch#> renumber <x_switch#>
set switch <z_switch#> renumber <y_switch#>
Either method should correct the errant logical vs physical slot.port mappings that were skewed when the accidental renumbering occurred.
A 'show switch' command may be used before/during/after the numbering correction process, to review the current stack numbering setup.
Also be aware of what is explained in 10749.
Photo of FAQ User
FAQ User, Official Rep
  • 13,590 Points 10k badge 2x thumb
Posted 4 years ago
There are no replies.
