SecureStack/G-Series 'set dhcpsnooping vlan' does not check for VLAN Creation
  • Article
  • Updated 5 years ago
Article ID: 12196
Products
SecureStack C3, firmware 1.02.01.0004 through 6.03.00.0022
SecureStack C2, firmware 5.02.01.0006 and higher
SecureStack B3, firmware 1.02.01.0004 through 6.03.00.0022
SecureStack B2, firmware 4.02.01.0006 and higher
G-Series, firmware 1.02.00.0043 through 6.03.00.0022
Changes
Configuring DHCP Snooping ('set dhcpsnooping...').
Issued the 'set dhcpsnooping vlan <ID_string> enable' command (12008) to enable DHCP Snooping on a VLAN or range of VLANs.
One or more of the specified VLANs does not exist.
Symptoms
The command is accepted with no error message issued, and is placed into the configuration.
Solution/Workaround
For the C3, upgrade to firmware 6.03.01.0008 or higher.
For the B3, upgrade to firmware 6.03.01.0008 or higher.
For the G-Series, upgrade to firmware 6.03.01.0008 or higher.
The new error message is: "Vlan number <ID> does not exist on this device.
For the C2, no functionality change is expected.
For the B2, no functionality change is expected.
Pre-upgrade workaround:
Use the 'show vlan <ID>' command to ensure that any referenced VLANs have been created either statically (via CLI) or dynamically (via GVRP or Policy).
Upon seeing the error message or otherwise determining that the VLAN does not exist in any form, use the 'set vlan create <ID>' command to statically create it.
Photo of FAQ User
FAQ User, Official Rep
  • 13,610 Points 10k badge 2x thumb
Posted 5 years ago
There are no replies.
