Serial Management 'PC' / 'Null Modem' Adapter Pinouts
  • Article
  • Updated 5 years ago
  • (Edited)
Article ID: 5301
Related to
PC adapter
Null Modem adapter
Goals
PC adapter pinout
Console pinout
Construct a PC adapter
Construct a null modem adapter
Serial management via console port
Solution
* RJ45 console port *
To construct a 'PC adapter' for serial management of most Cabletron/Enterasys devices having an RJ45 console port, the desired pinout is:
   RJ45    DB9   Conductor
1 Tx 2 Rx Blue
4 Rx 3 Tx Red
5 GND 5 GND Green
2 DSR 7 RTS Orange
6 DTR 8 CTS Yellow
The hookup between the PC's DB9 COM port and a device's RJ45 Console port would be:
  COM port => PC adapter => RJ45 straight-through cable => Console port.
The adapter p/n 6380041, bundled into DB9 console kit 9372038 and RJ45 console kit 9372065, is gray and T-shaped, with a white sticker labeled "PC".
These parts are referenced in 3377
If the sticker is missing, it probably has a different pinout, unless its a "home grown" adapter that was never labeled.
See 5130, for the procedure utilizing this part.
* DB9 console port requiring Null Modem cable *
To construct a 'Null Modem adapter' for serial management of Cabletron/Enterasys XSR, Vertical Horizon, ELS100-24TX(M,G), SecureStack, Matrix V2, and RoamAbout R2/AP2000 equipment, the desired pinout is:
   RJ45    DB9   Conductor
1 Tx 3 Rx Blue
4 Rx 2 Tx Red
5 GND 5 GND Green
2 DSR 8 RTS Orange
6 DTR 7 CTS Yellow
The hookup between the PC's DB9 COM port and a device's DB9 Console port would be:
  COM port => PC adapter => RJ45 straight-through cable => Null Modem adapter=> Console port.
Photo of FAQ User
FAQ User, Official Rep
  • 13,610 Points 10k badge 2x thumb
Posted 5 years ago
There are no replies.
