set fan speed for XOS
  • Question
  • Updated 2 years ago
  • Answered
Hi guys, how could I set fan speed for XOS switches?
Thanks in advance.
Photo of Arman
Arman
  • 122 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,036 Points 5k badge 2x thumb
You cannot manually control the fan speeds on any XOS switch, I guess if you get it hot enough you can make them go faster... :-)
Photo of Arman
Arman
Thanks Bill, in fact I'd like to set a lower speed, I guess fan speed is proportional to environmental temperature.
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,280 Points 10k badge 2x thumb
Hi Arman,
If the fan is running at very high speed, there is a known issue related to this. I don't have the CR number available right now, but it should be fixed in the latest patch of EXOS 15.5.3.4, which is the recommended version for the X430.
Photo of Arman
Arman
Great, I wil use the release.
Photo of Murilo Melo
Murilo Melo
  • 216 Points 100 badge 2x thumb
What about the x440-24t:
- showing 0 rpm speed  (all the time in "show fans detail" )
- but some devices we can see the fans working and anothers we can see fans not working
while x440-24p:
- showing 11000rpm (all the time too)
xos 15.7.1.4
Murilo Melo
Thanks for listening Brandon.
This is quite enlightening!!!
