Set Wireless Controller-Role with Policy-Manager
  • Problem
  • Updated 2 years ago
  • Solved
I want to set a Role on a Wireless Controller (C4110-2,  09.21.07.0007) with Policy-Manager  (6.3.0.182).  I was able to do it, but the role was created with "Bridge at AC" and I need "Bridge at AP". How can I change this?
Photo of Eisi
Eisi
  • 256 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Rich Upshaw
Rich Upshaw
  • 1,140 Points 1k badge 2x thumb
I don't believe you can change the topology this way once you build it.   Create a new Topology, this time, bridged at AP and then go to your Role and point the role to the new Topology.
(Edited)
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,854 Points 5k badge 2x thumb
you can change the topology once created (until it is used).
So you can create the topology through policy manager -> enforce -> change the topology from B@EWC to B@AP in the EWC GUI/CLI. Than you can continue to use policy manager. This will work until you modify the topology in Policy Manager = will survive next enforce.
Z.
(Edited)
Photo of Eisi
Eisi
Hello,
thanks for the hints. My problem is, that I dont know how to change the topology in Policy Manager or Netsight. I cant change the topology in the EWC GUI/CLI as it is grayed out (after enforce).
Photo of Joseph Burnsworth
Joseph Burnsworth
  • 2,328 Points 2k badge 2x thumb
What Pala is saying, is to change the topology used on the VNS and ROLE. Pick something else being used on your controller. Then you can change the Topology to what you need (B@EWC <> B@AC)
Then change the settings back on the VNS and ROLE
Otherwise, delete the whole VNS and Topology and create it as a B@AC Topology
Photo of Eisi
Eisi
Joseph,
sorry, I dont understand you. My goal is to do the configuration with Netsight, not with EWC GUI/CLI.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,154 Points 50k badge 2x thumb
You'd choose the right topology in PM - here a screenshot of my setup....
Photo of Eisi
Eisi
Ronald,
but my role needs an other vlan. I dont know how to set it?
You are not able to create/add a new topology (=VLAN) in Policy Manager.
You need to create the new topology in the WLAN Controller GUI.
After you've done that you'd configure the new role with the topology/VLAN that you've created.
(Edited)
Photo of Eisi
Eisi
Hello,
I found a workaround with only one  configuration on EWC:
-create VLAN in Policy-Manager with option "Always write VLAN to device(s)"
-Enforce
-change Topology with Wireless Controller-GUI to B@AP
-create Role in Policy-Manager
-Enforce
Thanks for all hints
