setting a captive portal on VX9000 managening remote AP
  • 2
  • Question
  • Updated 10 months ago
  • Answered
I have VX9000 managing multiple remote AP on diferent site and I want to set up a captive portal with basic onboard radius auth, and redirect the internet trafic to a remote proxy.
anyone can help.
thanks.
Photo of Hakim HAMOUCHE
Hakim HAMOUCHE
  • 120 Points 100 badge 2x thumb
Posted 10 months ago
  • 2
Photo of Ondrej Lepa
Ondrej Lepa, Employee
  • 6,100 Points 5k badge 2x thumb
Hello Hakim,
You can chose from CLI or GUI method creating the captive portal.
If you wish, you can use LDAP as authentication source also.
The redirection is more difficult here as you'd need to create a tunnel for this.
Otherwise I am afraid this is not possible. Would you tell me little more about the design?
Regards,
Ondrej
(Edited)
Hakim HAMOUCHE
I have :
- VX9000 in my datacenter.
- 5 sites (RF Domain) with multiple AP.
I want to set a WLAN with captive portal on these 5 sites:
how to create this : local VLAN or tunnel mode ?
who will act as DHCP for this WLAN...etc
who to redirect all trafic to my proxy
  • 6,038 Points 5k badge 2x thumb
Hakim,
as this is quite complex question I'd recommend you to contact one of our sales engineer trained in providing integrated solutions.
This will cover whole design plan and will provide better application of Captive portal features.
In short - you should keep the traffic locally bridged in guest VLAN (walled garden), then use i.e. post-authentication-vlan to distinguish between non-authenticated and authenticated clients. Authenticated vlan might be tunneled to your domain or anywhere you need. Non-authenticated will be soft-locked in walled garden.
DHCP is matter of design but this is not blocked by CaptivePortal so it might be external source.
Regards,
Ondrej
Hakim HAMOUCHE
who should I contact in France ?
thanks.
That should be Philippe Soirot <psoirot@extremenetworks.com>
Regards,
Ondrej
