setting an access point up for site survey
  • Question
  • Updated 3 years ago
  • Answered
Hi I am configuring an Access point for doing my first site survey with extreme access points one of the steps is to  Set both radios to a desired channel and max power.  Is there a reason why the radios have to be at max power 14dbm will this not lead to issues with over lap
Does anyone have a recommendation or a reason why the radios should be at max power
Thanks for any replies
Photo of Declan Liddy
Declan Liddy
  • 170 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,514 Points 20k badge 2x thumb
How many access points will you be using for the survey?
Declan Liddy
I will be using one with a power pack and move it around the floor using air magnet to do the survey
Photo of Doug Hyde
Are you verifying measurements based on a predictive plan and need to set the channel and tx power according to the plan or are you just looking for signal propagation based on where the AP is located?
Declan Liddy
I will be doing a physical survey moving the ap around the floor to different positions and taking readings with air magnet to make sure I have -67 db coverage on the whole floor
